Quality of life for fuel hauling
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by tmb0507, Nov 28, 2020.
  1. tmb0507
    tmb0507 Medium Load Member
    357
    197
    Aug 11, 2012
    Folkston, GA
    I'm curious from people who have hauled fuel longer than me what are some quality of life things you use to make the job easier on you. Such as things to make opening to drop covers easier on you.
  3. Life on Wheels
    Life on Wheels Light Load Member
    196
    177
    Aug 17, 2019
    New Orleans, Louisiana
    Nothing like a good old flat head screwdriver to open the lids. I don't think I really use any tools or gadgets to help me with my day-to-day tasks though. In the BOL room at the Holly rack in Las Vegas, there was a flyer on the wall for a type of roller to help you "walk out" your hoses that looked like it was maybe worth buying (I didn't). I think having a good routine with mental checklists for loading and deliveries is the biggest help.
  4. Life on Wheels
    196
    177
    Aug 17, 2019
    tscottme and Cat sdp Thank this.
  5. andhe78
    andhe78 Bobtail Member
    43
    75
    Jul 11, 2017
    Buffalo, NY
    Several of our older guys use the above tool.
    As a night guy, got to have an intrinsically safe flashlight. I also carry a small adjustable curve pry bar-works good for lids, but even better to pop locked caps when the lock is frozen. And speaking of winter, we always keep shovels on the truck to clear snow off fills. Also had to dig out my carhart fs helmet liner the other day-great for those nights in Canada where you have to stand around for an hour loading propane.
    Winters blow.
  6. RockinChair
    RockinChair Road Train Member
    5,085
    12,825
    Feb 19, 2012
    CC, TX
    If the fill box lids in your area have built-in handles, a fifth wheel puller will save you from bending over - and if they don't, use a long pry bar instead.
    tscottme and scott180 Thank this.
  7. GreenPete359
    GreenPete359 Road Train Member
    2,152
    5,101
    Oct 21, 2017
    Driving my recliner
    tscottme and RockinChair Thank this.
  8. scott180
    scott180 Road Train Member
    1,217
    4,221
    Dec 10, 2012
    Tooele, UT
    I used a fifth wheel puller to pull the lids as well as pop the caps too. I tried the roller thing. It works but at the time I had a good back so lifting and leaning back was easier. Intrinsically safe flashlight was also mentioned and a smart idea. Some tags are hard to see and you NEVER drop without confirming tags.
    I have had the station worker write on a piece of paper the product and put it in the fill pot as I recorded them. Find out what your boss wants you to do before this comes up.
    Use hose straps or bungee cords when running a pump just in case.
    A paper clip can be used to help a worn-out out hose cam but then get it fixed.
    Have caps for your product hose in case you have to drop diesel last.
    If you have internals that use cables to open have the shop make up a 4ft length and give you connections.
    Carrie an extra set of clothes. Only needed them twice in eight years but was glad I had them.
    Learn to burp the hose. This will get the hose clear and allow you to stuff the tank. Learn to never have to do this. I did this a few times with oversized tanks that I couldn't stick and the veeder-root was off.
    Ask for a strapping chart for the specific trailer you have.
    A six foot product hose is sweet for a single tank drop or if the other hose is just shy of reaching.
    Use the bucket and have spill pads on hand. Shouldn't need them but if you do you'll regret not having them. A cleaned up mess can be dealt with but if a customer needs to get involved it'll go to a new level.
    Learn what connectors you need for your setup and keep them in your fitting box Raise hell if things are borrowed with no note and are not put back.
    Look for scratches and scrapes when you enter a unfamiliar station. This will tell you where others have messed up.
    The best quality of life advice in my opinion is get into a routine.
    1. Spot truck
    2. Grab veeder-root and check address.
    3. Cones & pop lids
    4. Stick tanks
    5. Confirm compartment tags to paperwork. (People can and have changed the tags)
    6. Make sure everything fits before offloading.
    7. Walk the line each time before opening anything.
    Ect.
    This is the boring part but never allow yourself to start skipping things to save time.
    homeskillet and 91B20H8 Thank this.
  9. RockinChair
    5,085
    12,825
    Feb 19, 2012
    CC, TX
    They pounded it into our heads that you should always drop diesel first in order to help prevent cross-drops.
    Also, what are the tags you mentioned?
  10. scott180
    1,217
    4,221
    Dec 10, 2012
    Tooele, UT
    Diesel first I agree. Just not always possible. Dropping diesel first also flushes out your hose so no caps are needed. If diesel needs to be dropped last it doesn't evaporate like gas and will get over everything. That's why you have the caps. Just in case.
    I mentioned two types of tags.
    First is the ones you flip to just above your offloading hookup. I once had another driver flip them to the wrong product. Luckily my trainer had warned me this could happen so I always confirmed that my paperwork and tags matched. Only happen once.
    The other tags are in the fill pots. Reg, Mid, Prem, Diesel. If the tag was missing I'd have the attendant write one on a piece of paper and drop it in the box while I recorded it. Then call dispatch to get the go ahead recorded. Just a CYA incase it's the wrong product.
    I ALWAYS after hooking up looked into fill pot and read the tag, then walked the hose to the off load, read the tag there and only then did I open the valve.
    Anyone who says they never hooked up to the wrong tank is probably full of BS. We've all done it. But if you take all of 10 sec to walk your hoses you'll never cross dump. I never did. Almost did, but always caught it.
    Almost making a mistake like that is better than a cup of coffee to wake you up for the rest of your shift.
    Follow all the safety rules your trainer taught you. You'll be slow at first. We all were. Then one day you'll have the dance down and then your fast. I took 25-35 to offload and 15 - 20 minutes to load. No skipping safety steps. And there were plenty of guys faster than me being just as safe.
    Good luck and safe travels.
  11. mustang190
    mustang190 Road Train Member
    2,846
    6,115
    Jan 18, 2011
    Florida Panhandle
    I only haul aviation fuels.
    Knowing which FBO’s serve lunch and arrive then.
    Which FBO’s have the prettiest girls.
    Which FBO’s have the best restrooms (pretty much all of them).
    homeskillet Thanks this.
