Question about a truck and engine
Discussion in 'Ask An Owner Operator' started by Dieselforce, May 24, 2013.
  1. Dieselforce
    Dieselforce Bobtail Member
    33
    5
    May 15, 2012
    Grandville, Mi
    Does anyone know how the Cat C13 engine is? I'm just starting to look at trucks and I found a 2009 Peterbilt 386 with the C13 in it, the price is upper 30's and the truck looks nice with about 665,000 miles on it just wondered about opinions or thoughts.
    I would be hauling smooth bore tankers and Reefer units mostly. I would be plated for 80,000 lbs and hauling that pretty much all the time.
  3. BigCam9670
    BigCam9670 Medium Load Member
    417
    4,585
    Jun 12, 2012
    Hudson, NY
    Stay away from that engine, or any Caterpillar after 2007. You have been warned.
  4. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Especially the fuzzy ones with the wide stripe through the middle
  5. Ellipsoid
    Ellipsoid Bobtail Member
    31
    18
    May 8, 2013
    Sioux Falls, SD
    A c13 can do good mpg, but cat engines became HORRIBLE once they put a DPF filter on them. If you don't run cali, do not buy the truck. If you must run cali, then don't do a dpf cat. Get a Detroit, or even a cummins.
  6. Cat sdp
    Cat sdp . .
    20,984
    73,205
    Apr 8, 2012
    Orion's Belt
    No dpf cats.......ever !
    search the forum and you will find a ton of threads on these pos engines...
  7. 379exhd
    379exhd Road Train Member
    2,925
    3,153
    Jun 25, 2012
    rolling through hell
    Pre dpf great motor even know a heavy hauler that runs a c13. Post dpf horrible piece of crap. As much as I love caterpillars I'd never own another cat powered truck post 03. I hate the ACERT c15 we have fuel guzzling pile of crap in my opinion. Runs alright pulls decent but I'm throuroughly disgusted with the fuel milage. The c13 on the other hand was good on fuel would pull pretty well for as small as it is and was a good motor as long as it didn't have a dpf on it. If you don't run Cali as another member posted and can find one pre 08 you could make some money with it. And it didn't have the head gasket problems that the c15s had back in the day.
  8. Charli Girl
    Charli Girl Road Train Member
    1,371
    668
    Mar 23, 2013
    Houston,Tx
    I looked at a couple of those too.did my research and NEVER looked at another one...
    just saying...:biggrin_25513:
