question about coming down pass in co. in the winter
Discussion in 'Questions From New Drivers' started by Bigchevy, Sep 8, 2013.
  1. Bigchevy
    Bigchevy Light Load Member
    217
    82
    Jul 29, 2013
    colorado
    I have lived in colorado most of my life and have been over the passes more than i want to admit but i just got into a flat bed company and will be doing it a lot more and want to know the best way to come down i herd that you should not use jake when roads are ice so maby just in a lower gear? Usually im going over at around 78k. And every so often i empty any help would be nice
  3. baha
    baha Road Train Member
    4,137
    2,837
    Jul 25, 2013
    ga
    ice? not sure
  4. stevep1977
    stevep1977 Road Train Member
    3,704
    22,512
    Dec 23, 2010
    Chicago, IL
    Ice? Wouldn't do it lol
    snow or snowpack? The slower the better and with chains on, so yeah, use a lower gear so you can safely brake when needed. Plus if you are running heavy like that you'll have better traction than if you're lighter, but again, none of that really matters on ice
    baha Thanks this.
  5. NewNashGuy
    NewNashGuy Road Train Member
    1,616
    752
    Jul 27, 2011
    US and Canada
    Been there, done that. Just take it slow. That is the solution for everything. I used my jake btw.
    Bigchevy and baha Thank this.
  6. luvtotruck
    luvtotruck Road Train Member
    1,978
    1,161
    Jul 30, 2013
    Phoenix Arizona
    Ice! Don't move! That is my 2 cents worth!
    ewill71, DoneYourWay and baha Thank this.
  7. snowwy
    snowwy Road Train Member
    20,568
    13,293
    Jul 6, 2009
    if the roads are bad. the chain law will usually be up. everybody be going slow. unless they're a super driver.
    if the roads are dry. just pay attention to the signs. there's a ton of them.
  8. Shadow Captain
    Shadow Captain Light Load Member
    157
    101
    Jan 4, 2010
    Denver,CO
    You got on with Systems didn't you, how do you like it so far? Do their trucks have Johnson bars? Light application of Johnson bar or Jakes set on lowest setting, but try it on flat ground after the first snow to get the feel of it. Do they DH you MT up to Gypsum to pu the drywall or do the have loads up to the hills? Low gear naturally.
  9. TripleSix
    130,630
    Not a good idea. On ice, you're setting yourself up for a trailer jackknife. Gear down on the long descents. Save the brakes for when you really need them.
    "How far do I gear down?"
    Grossed out? Vale Pass?
    6th gear on a 9 speed, 7th gear on a 10, 8th gear on a 13 and 12th gear on an 18. No real specific gear, just somewheres near the bottom on the top side of the transmission and let the engine compression walk you down.
  10. Shadow Captain
    157
    101
    Jan 4, 2010
    Denver,CO
    You may have me on Mounteagle but pretty sure I've pulled all the passes west of Denver more times than any driver from TN, especially because I know how to spell Vail Pass. Drove I-70, what there was of it, before the first side of tunnel was even open.Did a gasoline run one year up to the ski areas and had to take Loveland pass everyday---until they close it due to road conditions---instead of the tunnel---haven't jackknifed yet! I didn't mean you should leave the Jakes on all the time or while you use the Johnson bar at the same time--takes a little practice!
  11. 58Skylane
    58Skylane Medium Load Member
    388
    276
    Mar 31, 2012
    Cody, WY
    Using "Johnson Bar" on ice?? What company and truck number are you? I want to stay away from you this winter!! Scares me that there's drivers out there using that method!
