Question about EDL rule
Discussion in 'ELD Forum | Questions, Answers and Reviews' started by Mikesuburban1, Dec 5, 2017.
  1. Mikesuburban1
    Mikesuburban1 Bobtail Member
    43
    13
    Dec 30, 2016
    Rockland county ny
    As a business owner I have 2 trucks 1999 pete so I know thats exempt but my 2006 international runs local never goes out of a 100 mile air radius so do I need to have a EDL for that truck?
  3. ZVar
    ZVar Road Train Member
    10,911
    23,826
    Sep 10, 2010
    Flint, MI
    Other than the age issue, the truck does not matter. It's the driver that matters for eld or not.
    If it's always driven by the same driver that meets the following criteria:
    1. Does not go over 100 miles
    2. Works no more than 12 hours a day
    3. Start and stops at the same location
    He needs e-logs if he does not meet that criteria 8 days out of 30
    If it's driven by the driver of the 99, say he works Mon-Thursday OTR need to do full graph logging. He comes back and on Fri uses the 2006 for local runs. He would need an e-log in the 2006, as with that schedule there is no way he could use the 8 day exemption, if he does that every week.
    If the 2006 driver is running 14 hours a day, it needs elogs (and should be doing paper logs right now)
    If that doesn't make sense to you, can you give an example of the drivers weekly hours to get a better idea of what is required?
    brian991219 Thanks this.
  4. Ridgeline
    22,177
    113,818
