Question about maximum cargo weight
Discussion in 'Questions From New Drivers' started by Kent D, Dec 23, 2024.
  1. Kent D
    Kent D Bobtail Member
    I know this is old. But I have been running into this lately. Truck with 52K GVW, what is its max cargo weight on an average dry van. My understanding is a dry van weight average 10K lbs and if that gets into the total truck GVW on payload, it only leaves 42K lbs for cargo. I got someone got a ticket for that lately running a 44k cargo and the total truck and cargo weight did not exceed 80K nor did any axle over weight 12k 34k 33k. So, can some one explain this to me?
  3. Hatt91
    Hatt91 Light Load Member
    153
    352
    May 18, 2018
    What was the ticket for exactly?
    tscottme Thanks this.
  4. tscottme
    tscottme Road Train Member
    There is no max legal cargo weight. There is a max legal gross weight & max gross weight rating. The road or the equipment may not allow 80k lbs.
    Like @Hatt91 asks what was the violation on the ticket specifically. If you are not on an STAA road you cannot assume 80k lbs is the legal limit.
    Hatt91 and Bean Jr. Thank this.
  5. Eddiec
    Eddiec Road Train Member
    2,319
    3,564
    Feb 2, 2015
    GVW ( Total Registered Vehicle Weight Allowed) - TARE Weight ( Truck & Trailer empty) = Net Cargo Weight Allowed to haul
    Example: 80,000 Pound Gross Vehicle Weight - 35,000 Pound Tare Weight ( Truck & Trailer Weight) = 45,000 (minus fuel) available net cargo weight to haul
    MACK E-6, Rideandrepair and tscottme Thank this.
  6. Ridgeline
    22,719
    123,167
    what kind of truck, axles?
  7. Hammer166
    7,601
    27,764
    Aug 18, 2007
    ~8600+' and loving it!
    You're totally misunderstanding GVW. On a tractor, that just means the weight rating of the axles adds up to 52k. The trailer will have its own GVWR, part of which is carried by the 5th wheel and part by the tandem. The tractor will also have a GCVWR, which is the max weight of the combination. The cargo capacity is GCVWR or 80,000#, which ever is lesser, minus the tare weight.
    Feedman, tscottme, Iamoverit and 2 others Thank this.
  8. Rideandrepair
    17,548
    56,859
    Aug 8, 2015
    I think avg dry Van wt. is around 14k.
    ElmerFudpucker Thanks this.
  9. Ex-Trucker Alex
    Ex-Trucker Alex Road Train Member
    1,548
    2,702
    Jan 7, 2023
    If you are talking about a common 5-axle semi, the usual GVW is 80K. 52K is really, really light for a 5-axle semi. Expect your unladen weight for a dry-van RIG to be around 32K, leaving you about 48K possible for cargo, assuming you still keep axle loadings legal (usually 34k for tandems, both trailer and tractor), and 12K to 14K for the steer (depending on the state and sometimes the steer tire width).
    I'm trying to wrap my head around your "flyweight" 52K GVW truck. Something does NOT make sense here....
  10. ElmerFudpucker
    6,952
    75,989
    May 17, 2024
    Did you tag it for 52? To possibly avoid the 2290?
  11. MACK E-6
    49,991
    237,943
    Maybe intends to only haul feathers. :biggrin_25523:
    Seriously though, I do know a company who does that with dump trailers. They haul from chicken plants to a rendering plant.
    In the OP’s case with his longbox-to-be, I can only figure he intends to contract to an LTL somehow doing deliveries where loads north of the mid 50’s are somewhat rare.
