Question about school problem
Discussion in 'Questions From New Drivers' started by Hope...!, Sep 15, 2016.
  1. Hope...!
    Hope...! Bobtail Member
    17
    Jun 21, 2016
    Hello everybody...! I joined aschool a week a go..already have class A CLP then start learning how to shift manually ..five or six students in a truck and three or four hour a day for all of us...my question is how to solve this issue with out get in trouble with them or any advice please...? Thanks..!
  3. Gunner75
    Gunner75 Road Train Member
    5,701
    9,076
    Mar 17, 2014
    Jackson Center Ohio
    Ask i missing something here? What's the problem?
  4. Spyke
    Spyke Light Load Member
    100
    105
    Jul 29, 2016
    I am not sure what you are asking,
    but it seems you are having trouble shifting?
    best and simplest advice I can give you are for learning when to shift and drill on your own with a plunger, and two rubber balls. One
    is gas and one is clutch. you can practice putting pressure and up and downshifting on your own. I can honestly say a weekend of drilling this put me ahead of my classmates.
    As it was explained to me, a handy but not foolproof way, and one you will outgrow in favor of feel and sound is that 3 through 5 is what you actually use to get "up off the couch" and 6 through ten are easily remembered along the lines
    of (15mph) 1 plus 5 =6 (th gear). 25 mph (2+5=7th gear) 55 mph equals what, tenth! And everything in between. Theres guys on here who may be able to tell you better but as a current fellow student, these things were game changers for me.
    ncmickey Thanks this.
  5. austinmike
    130,416
    Most of the problem in school is they make you use the clutch. Once you learn to shift without the clutch its a piece of cake - youll get it, just takes time. Good luck -
    Puppage and Spyke Thank this.
  6. Spyke
    100
    105
    Jul 29, 2016
    Looking forward to learning to do it like a pro. Till then, I'm doing the ten step every red light just to get up and moving ...
  7. Moosetek13
    Moosetek13 Road Train Member
    14,881
    18,813
    Nov 1, 2010
    Burnsville, MN
    Is your problem the number of students in the truck with such a limited time to practice?
    If so, you can't do anything about it except find a different school.
  8. Chinatown
    Chinatown Road Train Member
    77,372
    181,547
    Aug 28, 2011
    Henderson, NV & Orient
    That's about it!
    Or, just get the cdl and your first company will iron out the wrinkles.
    austinmike and Moosetek13 Thank this.
  9. Hope...!
    17
    Jun 21, 2016
    Thanks....a lot..all of you...chinatown please come again...The gov..pay for schooling ...could I change the school or anything related to that...I spent a week with more description and almost no behind the wheel practical experiance ...I have to do something about the rest seven weeks....If not....its clear I cant pass the test.. I think I will use the answer for .the problem how to learn shifting easily ... thanks again for that answer .but my veryfirst question is what would you do if you were in that school /to get enough time behind the wheel / Thanks everybody whose provide great for new comer ...
  10. Bisket
    Bisket Bobtail Member
    4
    Jun 17, 2016
  11. Bisket
    4
    Jun 17, 2016
    I had the same problem when I was in school, to many in the truck to get real practice in on shifting. The plunger idea is great, works well. I don't know how your class is set up but my class was divided into two parts every day. One part pre trip and air breaks and behind the wheel time. After I felt I had my pre trip and air breaks pretty much learned I used that time instead to practice shifting. You don't even need to start the truck, just run the gears over and over again. Sometimes you have to make the time to pick up in areas where your lacking. Good luck!
