Question About Something Wierd
Discussion in 'Questions From New Drivers' started by CrappieJunkie, Sep 15, 2014.
  1. CrappieJunkie
    CrappieJunkie Wishin' I was fishin'
    3,982
    18,764
    Mar 9, 2014
    In a van down by the River.
    Last Friday morning, as I was driving I turned my wipers off, but they kept going. Was a bit tired so turned on and then all way off but kept going and eventually stopped about 30 seconds later. Kept driving to delivery point. Hit Welcome Center on 26 in South Carolina. Stop for break, smell something burning. Turned truck off and pulled key out of ignition. Truck kept running though I was holding keys in my hand. All my electronics start shorting out. I have a 2011 Freightliner. Turned off power to batteries. Turned back on 10 seconds later. Doing same thing. Turn battery kill switch off. Call company. Was off for like 30 to 40 mins. Was sent to shop. Everything worked fine on way to shop, though still faint burning smell. Shop looked 7 hours couldn't find anything but small fuel leak. Truck seems to be running fine. Anny ideas why my truck would run while ignition off and keys in my hand???
  3. stevep1977
    stevep1977 Road Train Member
    3,704
    22,442
    Dec 23, 2010
    Chicago, IL
    Sounds like you got a hold of some bad acid
  4. TERRY51575
    TERRY51575 Bobtail Member
    7
    Jun 23, 2014
    Gremlins. Watch out they hang around.
  5. Trckdrvr
    Trckdrvr Heavy Load Member
    742
    621
    Dec 25, 2010
    Georgia
    Sounds like the time my speedometer cable went haywire..
  6. camaro68
    camaro68 Medium Load Member
    627
    290
    Dec 17, 2011
    Tennessee
    Not saying this is the problem, but sometimes when an alternator goes bad, strange things happen to an electrical system. My alternator,in the car, started going bad. The radio would come on when it was off. The high beams would come on when they were on low beam.
    It would start going bad at nighttime. I drove 24 miles home at night with the high beams on. Needless to say, that was a long 24 miles.
  7. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    Did you do the full pre trip??
  8. TracyN
    TracyN Light Load Member
    221
    148
    Aug 7, 2014
    Texas
    We had an 08 Freightliner that did something similar. Turned the truck on after fueling. Audible for low air came on but air pressure was fine. Lights wouldn't come on. Then it started raining and I had no wipers and the radio wouldn't shut off. Drove the 30 miles or so back to our yard and had the shop look at it. They had it for a few hours and couldn't figure out what was wrong with it. In their words, it was possessed. They couldn't figure it out and had to assign us a different truck to get us on the road again. So in saying all that, no idea what is wrong other than to say it could be possessed. LOL!!
  9. zenaddler
    zenaddler Light Load Member
    158
    130
    Nov 7, 2013
    Install smoke alarm b 4 sleeping
  10. Moosetek13
    Moosetek13 Road Train Member
    14,699
    18,483
    Nov 1, 2010
    Burnsville, MN
    Check the connections to the ECM for corrosion.
  11. xsetra
    xsetra Road Train Member
    5,117
    6,987
    Aug 21, 2011
    I had a gremlin in my truck like that. Like mentioned above, my alternator was overcharging batteries (pre computer engine). I could smell the acid cooking while driving. Truck wouldn't shut off until I disconnected batteries. Changed batteries, alternator and some cables. Worked fine.
    Also had a truck that used to have a Qualcomm installed. When the last owner removed it they just cut the cable at the floor. When the ends corroded and wires started to short, I can't tell you all the strange things that started to happen. Point is check for any wires that are shorting. Good luck
