Question about STAA highlighted routes in rand McNally atlas
Discussion in 'Trucking Industry Regulations' started by Buckeye91, Apr 6, 2015.
  1. Buckeye91
    Buckeye91 Road Train Member
    1,095
    677
    Sep 26, 2011
    Midwest, USA
    So here's a question that I've been wondering. On the rand McNally atlas it has routes that are highlighted because they are STAA compliant routes. After doing some research on STAA I've seen that they have standard dimensions for length and width and weight. But I couldn't find anything about height. So here's my question. If a route is highlighted as a STAA route in the atlas. Does that mean that there are no bridges with a height of less than 13'6"?
  3. CargoWahgo
    CargoWahgo Road Train Member
    3,912
    3,945
    Jan 10, 2012
    Louisville, Kentucky
    Nuh..
    Nuh.
    paul_4lp Thanks this.
  4. NewbiusErectus
    NewbiusErectus Medium Load Member
    586
    617
    Jun 27, 2012
    look up a legal route that you know of -- which also has a low clearance or restricted bridge weight. the orange highlight will be there. Rand doesn't know whether you're 12 ft or 13'6, or if you're 34k ,, or 80k.
    Buckeye91 Thanks this.
  5. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    STAA = 13'6" tall, 8.5' wide, a 53' trailer, and no limit to the tractor length.
    otherhalftw and Buckeye91 Thank this.
  6. TLeaHeart
    TLeaHeart Road Train Member
    4,169
    2,614
    Apr 1, 2008
    casper, wy
    sorry, but STAA does NOT regulate height. from http://ops.fhwa.dot.gov/freight/publications/size_regs_final_rpt/index.htm#cmv
    There is no Federal vehicle height requirement for CMVs. Thus, States may set their own height restrictions. Most height limits range from 13 feet, 6 inches (4.11 meters) to 14 feet (4.27 meters), with exceptions granted for lower clearance on particular roads.
    The STAA authorized the establishment of a "National Network" for trucks where Federal width and length limits would apply.
  7. Buckeye91
    1,095
    677
    Sep 26, 2011
    Midwest, USA
    I just bought my atlas specifically for height as a backup to the "all stays truck and travel" app that lists low bridges. Kinda sucks to know that the highlighting doesn't mean it's safe to travel height wise.
  8. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    I challenge you to find 1 STAA route with less than 13'6" clearance.
  9. NewbiusErectus
    586
    617
    Jun 27, 2012
    Buckeye91 did say STAA route, but he also said RM highlighted routes. Are both one and the same?
    If so, I do know that OH-183 in alliance, OH is highlighted in the RM. And I've seen countless trucks stuck under a bridge there.
  10. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    The MCRA also has a section on restrictions such as low clearances.
    [h=3]NATIONAL NETWORK[/h]The STAA authorized the establishment of a "National Network" for trucks where Federal width and length limits would apply. It includes the Interstate System and other designated highways which, on June 1, 1991, were a part of the Federal-Aid Primary System in effect at that time. The NN now totals over 321,890 kilometers (km) (200,000 miles) of highways across the Nation. The non-Interstate NN highways are listed in 23 CFR Part 658, appendix A.
    http://ops.fhwa.dot.gov/Freight/publications/size_regs_final_rpt/index.htm
    xsetra Thanks this.
  11. TLeaHeart
    4,169
    2,614
    Apr 1, 2008
    casper, wy
    there are over 30 pages of them listed within the front of the atlas.
    tucker Thanks this.
