i wonder how your law looks on dead axles , i notice that many members talk bad about tag maybe this is one of reasons....
hello i was trying to find but without success
when truck have tag or lead axle in US
what law allows to operator
here for example 2axles on bogie are 19t legal and drive one get in most cases 11.5 and tag 7.5
some customers chose 9.5+9.5
some with different ratio there is lot of choice
does your law require to have same weight on each axle or you can do also like we have
so we always get 50% more weight on drive axle than you
question about tag and weight law
Discussion in 'Trucks [ Eighteen Wheelers ]' started by 98989, Apr 11, 2012.
The only way to have a single axle to be able to carry more than 17,000 lbs is if the next closest axle is further than 102 inches away from it centerline, then you're allowed for each axle to carry 19,000 lbs or 38,000 lbs as a spread axle tandem combination. This can also be spread to a 122 inches centerline to centerline of each axle for a for 20,000 lbs per axle and 40,000 lbs for the tandem. Any single axle in the center of a trailer can carry 20,000 lbs if each of the tandem axles in front or behind it are at least 122 inches away from it. If it is closer than 122 inches than the axle combination will be considered a tri-axle combination and the total weight carrying capacity will be reduced, depending on a math formula you have to use. A tri-axle combination with a 117 inch centerline from the two outside axles is only capable by the US Federal Bridge Law to carry 42,500 lbs on three axles. Now this combination doesn't have to have the weight equally spread between the 3 axles. You can have a standard tandem carry 34,000 lbs while the third axle carries 8,500 lbs. Here is a picture of a typical tri-axle combination trying to take full advantage of the bridge law with a light weight single tire third axle and wide spread. This axle combination is 117 1/2 inches and can carry 42,500 lbs on it. The single tire front axle is rated to carry 12,500 lbs, but as you add weight above the 8,500 lbs to this axle you have to reduce the weight the tandems carry. Any two axles that are closer than 102 inches from centerline to centerline are considered a close tandem and can only carry 17,000 lbs or 34,000 lbs as a tandem, so you either keep them at 49 inches or spread them past the 102 inches depending on your application
king Q and logtrucker25 Thank this. -
I edited my post to reflect a mistake I made in a measurement of the tri-axle combination. I said 105 1/2 inches, when it should have been 117 1/2 inches
is a big mess, since I hardly ever drive on inter state hwy, here in Florida you can put 44k on any tandem, but no more than 80k on a 51 feet or more wheel base, on my try axle dump trucks I can gross 70k which goes like this steering axle I have 425 65 22.5 tires 19,965lbs, drop axle are 11 22.5 you can put 13,310 lbs and the tandem 44k but not to exceed 70 gross that's Florida.
thank you for your explanation sound very complicated , and i now understand why your operators are skeptic about tag...
here we can have 11.5t(25350lbs) on drive axle total bogie on truck cant exceed 19t(41900lbs)
however you can shift weight from tag axle to drive on lower speeds and you can get max 33000lbs on drive axle
....and another question how much would be possible to have on our trailers they have 103inch from first to last axle and mainly 385mm wide tires
some trailers have even 455mm tire but this is rare -
If you use the 425/65R22.5 than the weight rating of the tire will exceed the weight carrying ability of the axle restrictions by using the Federal Bridge Law.
If you look at the picture this trailer has the 445/55R22.5 tires on the rear tandem axle combination. These tires are rated for 10,400 lbs or 20,800 per axle with a combined rating of 41,600 lbs on the tandem, but this closed tandem can only carry 34,000 lbs on these two axles by the US Federal Bridge Law. The tires have to be rated to carry more than the axles by law, otherwise the tire becomes the limiting factor if a weight enforcement officer wants to get picky. If the axle and suspension are rated at 15,000 lbs by the suspension manufacturer, then the axle/suspension will be the limiting factor regardless of what tires are mounted or axle spacing the truck/trailer is built with. So everybody builds the truck or trailer to handle more weight per axle than the Bridge Formula will allow, uses tires built to handle more weight than the axles can carry by the axle manufacturer rating, just to be able to cover every possible possibility of weight enforcement in the different states. -
There is another factor to also consider, but I haven't seen enforced........yet anyway
The 385 tire is narrow. The Federal Bridge Law also goes into depth about tread width and the tires surface contact area with the road. This tire isn't used at all in this country due to the weight limiting factor of this, you may see it on steer axles on construction vehicles, but that is usually the only application it's used in. You will see a few trucks/trailers with the 425 tires, but again this tire is limited by its width/contact patch to it weight carrying ability.
The reason the newer 445/55R22.5 tires have become popular in the US is they are wide enough in tread width, as to not limit the axle weight that can be carried.dwmac71 Thanks this. -
mr Haney thanks for explanation
i wanted ask for standard european semitrailer which have 1310mm wheelbase between two axles or 2620mm between 3axles
this kind of trailer is allowed to carry 3x8t on bogie(3x17637=52911lbs) , but you will not be fined if you have more weight on front two and less on last (this is used sometimes in this http://www.cargobull.com/en/technology/load_spread_program_c146.html )
if you have more than 1400mm between axles you than have 3x9t(3x19841=59524lbs)
our law allows to 385to be used for weights up to 19841per axle or even 22046 if tires are capable -
this sounds good i excepted that you dont have so much flexibility for loading
we have here weight on front two axles on dump truck 2x10t (2x22k)but most trucks dont have such axles because it is not possible to have such weight on front axles without exceeding rear weight but around 19850lbs
two rear axles are together 41900lbs
total weight for 4axle tipper here is 70560lbs most of them are about 30870 empty
so there is no weight bridge formula
however since it cover short distances you can always overload it, about 90000lbs is normal
some guys goes as much as 155k on 4axles
you can register truck as overweight and pay registration more
than you can load as much as truck manufacture will allow it
i saw many trucks registered as 123500lbs.....police officers will accept that but problem appear when you have to go on scales than you can load less than truck with normal plates (only 68350lbs)
