Question about the clock
Discussion in 'Questions From New Drivers' started by Boogers, Apr 23, 2012.
  1. Boogers
    Boogers Light Load Member
    I'm curious as to how exactly does this 70hr clock work...as in, how does it work when we get time back.
    Forget the 80 hour because my company doesn't operate off that.
    Say...I'm on duty 10 hrs/day...after 7 days and 70hrs, I rest, then I get 10 more hours back?
    So I wake up with 10 hrs back on my clock to work with, after 10 hours, I rest. When I wake up, I have another 10 hours??
    Seems to me, that I would never need a 34hr reset.
    I ask because I'm on a 34hr reset now, but found I have 8 hrs on my clock today.
    I certainly don't want to do any resets if I don't have too.
    If the wheels ain't turnin, I ain't earnin.
  3. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    It is 70 hours in 8 days, so if you average exactly 8.75 hours per day, you'll never need a reset. you will always work 61.25 hours per week.
    if you work 11-14hour days, you will need to reset weekly, but your total hours worked per week will be higher (more miles).
    Boogers Thanks this.
  4. Boogers
    Good info...
    I want to make as much money as possible.
    From what you stated, it seems maxing out every day and taking the reset makes me more money.
    Correct?
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    If you are not sure of how the 11/14/70 clocks work, I would suggest you contact your Safety office and have them explain how those and the 34 hr reset works.
    You should know at the end of your day how many hours you have left on the 70 hour clock. This will allow you to determine how many hours you have left to work the next day.
    If you suddenly found 8 hours while you are on a 34 hr reset, then somewhere you missed something in your daily logs.
    Mark
    Onetruckpony Thanks this.
  6. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    correct. The theoretical maximum hours you can drive interstate in a week is 81. to do that youd need to drive 11, take off 10, drive 11, take off ten... for 5 days straight, reset on the 6th & first part of the 7th day, and then drive 11 more.
    Even if you had the freight scheduled to do it, you'll never have that perfect week because pti's, fueling, & drop/hook will take up some onduty time. still 70+ hours are doable and that extra 8+ hours would be 500ish more miles/week
  7. MysticHZ
    MysticHZ Road Train Member
    5,882
    5,692
    May 28, 2010
    Just keep moving ... you had the abilty to run 400+ miles, took a reset instead. Even if you run out your 11 the next day, you're still going to be a day behind and down a 150 or so miles for the week.
    Manage your hours to the loads you get.
  8. Onetruckpony
    Onetruckpony Medium Load Member
    544
    372
    Jun 11, 2011
    Huh?
    The Bird Thanks this.
  9. Boogers
    Never mind...
    I was thinking for some reason their was an 80 hr, 8 day clock too, but I realize ...not so much.
    It's just an 8 day/ 70hr clock.
  10. Boogers
    I've figured it out....in part, due to the response here, thanks
    The hours onduty 8 days ago, I get back when they fall off the " back end" of the clock.
    Seems like if one just busts their butt and drives all out every day, assuming he has the loads for it, and takes the reset when it comes...one can make more money vs coasting and managing the clock by driving less per day and not taking a reset.
    Either way, that's too much managing, I'm going to just drive all out on the loads I get.
    Besides, if I get there a day early, I get layover pay. So miles+layover pay makes me more money. It also gives me some wiggle room if something breaks, traffic, weather..ect
  11. The Bird
    The Bird Medium Load Member
    386
    268
    Apr 10, 2012
    White Rock, NM
    IF you can depend on getting a restart. If not, I would manage your hours. I would take 9 hrs off (it never works out exactly like that) my 70 everyday, that way I could drive 7 days a week.
    Mmmmm... you might want to check on getting layover pay if you're early. Detention pay usually is based off your appointment time. You are correct in that you should get to your destination as soon as possible to give yourself leeway if something should go wrong.
