Question: Air Brake System - Relay valve, and Spring brake valve (Balanced position)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by John.doe0289, Feb 4, 2020.
  1. pushbroom
    pushbroom Road Train Member
    1,780
    7,319
    Sep 1, 2012
    You are correct, yes
    It should put the relay valve into a balanced position as long as there is no air leaks in the system. If there was a slight leak at the one brake pot it would come off balance.
    Relay valve manual attached, you may have read this already. Might be a help to someone else.
    John.doe0289 and SAR Thank this.
  3. pushbroom
    1,780
    7,319
    Sep 1, 2012
    With the unhelpful posts cluttering up this place I'm not so sure
    SAR and spsauerland Thank this.
  4. x1Heavy
    x1Heavy Road Train Member
    34,016
    42,139
    Mar 5, 2016
    White County, Arkansas
    Any posts that takes a side swipe is particularly unhelpful and would be the last one on the list on my end. As far as trolls and other issues with any site, tribal virology so to speak among the Community will take care of that fast enough if it is outrageous.
  5. John.doe0289
    John.doe0289 Bobtail Member
    13
    10
    Feb 4, 2020
    "As delivered air pressure is changed, the valve reacts instantly to the change, holding the brake application at that level."
    Alright, that makes perfect sense. So the SR-1 is also balanced along with the rear R-14 (or R-12).
    pushbroom Thanks this.
