Question - Air Sound in Cab when I press Fuel / accelerate .
Discussion in 'Volvo Forum' started by JerryD13, Mar 15, 2019.
  1. Newto Trucking
    Newto Trucking Medium Load Member
    359
    225
    Dec 26, 2013
    NE Illinois
    You might be able to hear egr valve leak if you remove 7th injector completely and stick stethoscope in there. With a software you can see negative reading on a egr delta pressure sensor on a cold start up when egr should be completely closed to speed up warm up process.
    Volvod13vnl Thanks this.
  3. Newto Trucking
    359
    225
    Dec 26, 2013
    NE Illinois
    Your best option to find hard to find leak
    KB3MMX and Volvod13vnl Thank this.
  4. Volvod13vnl
    Volvod13vnl Bobtail Member
    19
    4
    Mar 4, 2019
    On cold start when the engine is loader that means the egr is closed right?
  5. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    yes on cold start egr is closed, but you van have a egr valve leak when you do a boost psi test most of the time they do leak a little bit from the valve disc or the sealing surfaces.
  6. Volvod13vnl
    19
    4
    Mar 4, 2019
    Thanks Nasriza!The pressure was dropping pretty quick and i dont see any leaks.whats so ever.What are your thoughts.
  7. Blondemel
    Blondemel Bobtail Member
    D dds-zzz@ss@ssssssß Nikko s
