Well I made the change to a company that uses elogs and so far I think it's alright except for a few bumps in the road learning curve and the IT guy is not much help so I got 2 questions for anyone that might know the answer
1 . When stoping for the 30 min rest do you just go off duty or do you have to hit off duty then sleeper berth?
2. When you want to force a 10 hour reset is it the same process or again just go off duty and watch the clock for 10 hours.
I came from from a regional trucking company were I was home almost every night and on loose paper logs so the sleeper option is something I never used before since I always had enough time to get home and do my reset "cough cough" . Thanks for the help
Question for anyone using "people net " elogs
Discussion in 'Trucking Industry Regulations' started by skinnytrucker79, Jan 21, 2014.
Page 1 of 3
For the 30 minute break, just go "off-duty" or "sleeper birth" for 31 minutes.. 31 to ensure you have done 30,,,elogs can fool ya...
For the 10 hour break, do the same.... and yes, you have to wait for the actual time to expire. You can't just set the elogs to "off-duty" and drive. It will go to the drive line if you move over a mile. -
I have people net and I just go off duty for 30 minutes when I take my break.
As far as the 10 hour reset either go to sleeper or off duty for 10 hours and then you have your reset. -
So for my 10 hours say I have exactly 2 hours left and I want to shut down at that point all I have to do is count 10 hours from the time I went off duty regardless when the clock is still counting down? And once it "sees" 10 hours regardless it will reset itself?
SheepDog Thanks this. -
If you have been off duty for 8 hours and you want to go ahead and get your ten hours off then yes stay off duty for 2 more hours and you will have a full 10 hour break. If you go on duty it will start all over from the beginning so make sure that you can stay at the place you are loading or unloading. You can split the 10 hours between sleeper and off duty.
Sorry for the repeat question. But regardless long as I don't mess with it once I hit off duty the next time I look at the clock it should reset itself? Regardless how much time you got left. I don't know how "smart" the system is yet
No problem...
Okay, so lets say you have used only 8 hours of your 14 and decide to call it a day. You put yourself in the sleeper or "off-duty", if you at home or whatever. Once the clock reaches 10 hours, your 14 will restart from that point or any point after that, that you decide to start using it. In other words, you will be able to work, once the 10 hours is reached but, you don't have to at that point. Now, if you start working before the 10 hours is reached, you are still working on your original 14,,,,follow? -
popcorn169 Thanks this.
Another little hint with e-logs.... When your 30 is up manually go to on-duty or drive. That way the system will not auto adjust incorrectly and cause you to take a 29 minute break.
-Steven
Page 1 of 3
