Question for building mounted antenna?
Discussion in 'CB Radio Forum' started by nickdixon14, May 30, 2017.
  1. nickdixon14
    nickdixon14 Bobtail Member
    11
    May 30, 2017
    i need the best option for a cb antenna for my scale house but do not want a 18' bas antenna. The roof is about 20' up with a all metal roof, wood a popular magnetic cb antenna work? or do i need a NGP antenna?
  3. nickdixon14
    11
    May 30, 2017
  4. buddyd157
    buddyd157 Road Train Member
    13,510
    34,599
    May 25, 2017
    under a shade tree
    at one employer i was at, they had a simple cb antenna that would fit a truck's mirror mount. they had this mounted on the side of the building, and just barely reached over the roof top.
    i would at least use a 3 to 4 footer antenna. magnetic base.>??? uh, maybe, maybe not, see if you can get a side mount kit, just above the window? where the cb will be located?
    side mount
  5. nickdixon14
    11
    May 30, 2017
    are you suggesting this with a NGP mount?
  6. buddyd157
    13,510
    34,599
    May 25, 2017
    under a shade tree
    the one i saw mounted, was a simple cb antenna to a simple antenna mount. your building is all metal..??
    i don't think you'll have any problems
  7. nickdixon14
    11
    May 30, 2017
    no its a 2 story 18x20 center block building with sheet metal roof
  8. buddyd157
    13,510
    34,599
    May 25, 2017
    under a shade tree
    where will the cb be, on the lower level or upper level.
  9. nickdixon14
    11
    May 30, 2017
    its on the upper level inside the office mounted under the counter with the coax running outside
  10. Ridgeline
    22,192
    113,895
    Let's start with the questions
    where are you at?
    How much do you want to spend?
