Question for Max Signal
Discussion in 'Truckers Forum Sponsors - Supporters Forum' started by CMoore2004, May 14, 2008.
  1. CMoore2004
    CMoore2004 Road Train Member
    1,119
    110
    Nov 2, 2007
    OTR
    Strongly considering getting your wireless mobile amplifier package for my truck, but one thing's bugging me. The antenna you supply is magnetic, and from my understanding with my past magnetic antenna, you need a fairly large "ground plane" or something like that. Well, it'd seem there's not a bit of magnetic material on my truck, at least somewhere I'd get reception. I actually had to pay the $8 for that little piece of steel they call "The Plate" for my Sirius, but I don't think that'd suffice as a ground plane. How would I go about mounting that on the outside of my truck. Is it going to hurt the wire to run it through the door like I do my Sirius and CB antenna? I drive a company truck, and I don't imagine they're too fond of me drilling holes (I'm not either, even on my personal vehicle).
  3. Scarecrow03
    Scarecrow03 Road Train Member
    3,411
    7,443
    Sep 27, 2006
    In Your Head
    The amplifier I got from Maximum Signal came with a mirror mount for the antenna and I had no problems with it.
  4. CMoore2004
    1,119
    110
    Nov 2, 2007
    OTR
  5. Scarecrow03
    3,411
    7,443
    Sep 27, 2006
    In Your Head
    Ok, I mistakenly put mirror mount instead of magnet mount in my other post.
  6. CMoore2004
    1,119
    110
    Nov 2, 2007
    OTR
    Then what did you stick it to on your truck. I'm in an '04 Century Class Condo and short of buying another "plate", there's not a place I can find that a magnet will stick to any higher than my fuel tanks. Perhaps I could shove it back on top of my securement boxes, but I think those are aluminum.
  7. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    I've got a mirror bracket mount on mine.
    This antenna isn't a mag mount. You can't see the mount very good but its the mirror bracket mount that I've got.
  8. Maximum Signal
    Maximum Signal Light Load Member
    110
    15
    Sep 29, 2007
    Buffalo , New York
    That DBSW819 you are looking at is not strong enough for your truck it is made for small cars . You would need the IVWA819 . We could make a custom package for you , Just give me a call and we can figure out what antenna you can use and go from there
  9. CMoore2004
    1,119
    110
    Nov 2, 2007
    OTR
    Just out of curiosity, how is the DBSW819 not strong enough when it says the gain is the max allowable by the FCC, the same as the other amplifiers?
    Edit: I just want to clarify that I'm not trying to be a PITA here, I just thought that the same gain would work the same on both amplifiers.
  10. Maximum Signal
    110
    15
    Sep 29, 2007
    Buffalo , New York
    It is made for smaller vehicles (2 to 4 dooor small to mid size cars)and only has a range of 2 to 3 feet. It was made right to Alltel spec and they did not want any more power.THE IVWA has much more range
  11. CMoore2004
    1,119
    110
    Nov 2, 2007
    OTR
    Ok, I looked around a little bit and I think I have an understanding. The gain that is listed is only the gain on the external antenna part? It really doesn't make sense to me, since Cyfre's website even says 28dB gain, but perhaps the gain is on the originating signal, able to improve its quality/strength by 28dB? Then it only emits a small amount of power on the internal antenna?
