question for reefer owners
Discussion in 'Ask An Owner Operator' started by homesick, Apr 26, 2009.
  1. homesick
    homesick Light Load Member
    161
    8
    Nov 26, 2007
    memphis,tn
    reefer owners how much do you pay to have your units serviced?i just got a thermoking unit and was qouted $300.00 dollars for service at thermoking and that seemed to high.
  3. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    Depends on what they mean by "serviced". That sounds like about triple, but I do my own, so I can't say. The basic stuff is pretty easy to do. Oil change, filters, belts, alt. Easier than working under the hood of a 4 wheeler.
    I'm sure they do more than I do, but $300? I'd ask for a full descripion of services performed.
  4. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    do you change the fuel filters also it looks easy to change the oil and filters
  5. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    Yes. The fuel and oil filters are the easiest part. Right in front, easy easy access.
  6. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    i think i will do it myself are the belts are hard to tighten up
  7. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    Depends which ones, but generaly speaking, no.
  8. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    will you be on the road in the morning i might need to ask you some questions how much are you usually out of for parts for the oil change and filters
  9. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    2 oil filters and 1 fuel filter + 5 gallons oil cost roughly $75. But I'm thinking you'll pay more if you go to that TK dealer for these parts. You should find them cheaper at a tractor supply type outlet.
    Go open your reefer doors and peek inside. It's all right there.
  10. homesick
    161
    8
    Nov 26, 2007
    memphis,tn
    thanks for your help 2 oil filters + fuel filter and thats it nothing else i need to know about
  11. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    Look, there's a vast difference between a full service that the Thermo King dealer is offering, vs just changing your oil and filters. I'm thinking maybe you ought to at least take it to a truck stop or a general diesel maintenance shop and get the basic type reefer PM service which should be around $100, and if they'll let you, watch and ask questions.
    Don't take this the wrong way dood, but.... have you ever changed oil in anything? If so, and you have done your car/pick-up at least a few times, then you'll have no trouble with the oil/filter change on your reefer. It's all the same, except you'll be either standing on a ladder or the catwalk of your tractor, and holding the oil catch container, instead of it laying on the ground like with your 4-wheeler.
    But like I said prior, and do note this, you will get a very thorough inspection from a pro, in addition to just changing oil and observing that the belts are still there.
    There used to be a guy here who'd posted tech tips on reefers by the name of reefertech (or close), who'd answer questions like yours, but I havent seen him post in some time. Probably got banned like most everyone else here. Would be worthy of a quick search on your part tho.
    Do you own your own reefer, or looking to buy one?
