Question from JCW
Discussion in 'Prime' started by DragonTamerBrat, Nov 29, 2011.
  1. DragonTamerBrat
    DragonTamerBrat Road Train Member
    2,742
    985
    Jun 6, 2011
    At what point do you engage your PTO and keep it engaged? It was never covered by a trainer.
  3. Seebs
    Seebs Medium Load Member
    665
    271
    Mar 4, 2011
    Considering I have the same truck. What is a pto? The axle diff?
  4. Tardis
    Tardis Light Load Member
    211
    118
    Nov 6, 2011
    banned or retired
    PTO power take off, used to drive rotary machinery using engine power. You only have one if you have a hydraulic pump, blower or other piece of equipment that needs to be powered. Usually you don't leave it on but only engage it when you are loading, unloading or doing something that needs these special functions like raising or lowering your dump body or starting a blower to load, unload a hopper body.:biggrin_2558:
    In other words you don't turn it on and leave it on.
    harleysmith64 Thanks this.
  5. Mudrunner
    Mudrunner Light Load Member
    228
    25
    Jun 17, 2008
    San Dimas, CA
    That is for the tankers. It has nothing to do with refers or flatbeders.
  6. Mudrunner
    228
    25
    Jun 17, 2008
    San Dimas, CA
    The axle diff is to be engaged while the wheels aren't spinning out and not to be used above 45 MPH. It's a very small gear the engages the other diff. :biggrin_25522::biggrin_25514::biggrin_2559:
  7. grumpygroundhog
    grumpygroundhog Light Load Member
    112
    32
    Feb 11, 2010
    Fort Myers, Florida
    PTO- Psychopath Truckdriver Onboard
  8. Seebs
    665
    271
    Mar 4, 2011
    Its not supposed to be used over 45 mph? Oops. :biggrin_2559:
  9. Mudrunner
    228
    25
    Jun 17, 2008
    San Dimas, CA
    Yeah if you seen the gear that engages the 2nd rear diff you would ####. Its not very big.
  10. Seebs
    665
    271
    Mar 4, 2011
    Interesting. My trainer had taught me to use it when I bobtail or are pulling an empty load.
  11. cwc
    cwc Medium Load Member
    539
    58
    Apr 14, 2008
    richmond, va.
    The trainer told you wrong:biggrin_25513: It is only use for traction when you are stuck in mud or snow or ice in some situations when you have a heavy enough load. It might not help you if you are empty. Not for highway use. If you need more traction when you are light, you will have to throw the chains on if you have them available. Unless you are sitting deep in a mudhole then you will have to call a tow truck.
    Mudrunner Thanks this.
