Question > How to do a "Forced Regen on Volvo D13"
Discussion in 'Volvo Forum' started by JerryD13, Dec 13, 2016.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    Question please >
    How can a driver do a "Forced Regen" on a Volvo D13
    - there are times when we get these check Engine lights - Shut Down Lights -
    D13 will NOT do a conventional regen >> saying conditions are not met !
    Thanks in advance !
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    d13 will not do a forced regen unless the truck is asking for it if you try to do it, it will go into check status menu and it will show you temporary lockout.
  4. Pnwtrucker
    Pnwtrucker Medium Load Member
    383
    821
    Nov 5, 2016
    I don't know about Volvo but Pete you make sure cruise, and jakes switches are off then with truck idling hold the manual regen button down for like 10 seconds and off it goes. But if it's already derated and lights are all on it won't let it manually regen
  5. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    Can't do it, have to be hooked up to their system to override and do a forced regen.
  6. En10
    En10 Bobtail Member
    I am having the same problem as mentioned above. My question is, how much longer can I drive with the check engine light on due to failing the PARKED REGEN. Ps. my soot level is not passed the middle point!! Also, any suggestions where I can get my dpf filter cleaned for a reasonable price? Thank you all!!
