Hi Folks, as a newb here, just getting BACK into the industry (I pulled a lowboy for an excavating company from the early 80's to the mid 90's, and my ears are STILL ringing from that &#&$* 8v-71!). Anyway, the first tractor I drove was a 1962 Ford T850 pulling a 43 foot lowboy trailer with a 534 gasser and a 5 speed tranny and this weird, 3 position, electric-to-air splitter that worked as such: Run 1-5, then back up into 2 with the splitter up to the middle, then top then 3middle,top....Exactly like a 13 speed with a 3 position handle, except here's the difference: When you split to the middle, it shifted the front diff into high gear, and put the rear diff in neutral. When you split to the top, it would put the front diff into neutral, and engage a taller gear in the rear diff. So, in effect, once you got out of low range, you were only driving with one differential/axle at a time. The system worked FLAWLESSLY! By about 1984, we "updated" to a '73 LT9000 with a 318 detroit (with dual exhaust, putting one of the LOUDEST mufflers ever made next to your ear) and a REAL 13 speed(and over a million miles). Lately, I've been seeing late-model tractors for sale with 9, 10, and 13 speed trannies AND "2 speed rears" .
Here's my questions:
- Do most late model tractors have the traditional layout of two rear differentials, and a power divider on the front diff.?
- And are there some trucks out there with tandem rears, but only ONE diff actually being driven, and the other axle is "dead" (there just to carry weight) even though they LOOK like both are drivers?
- What's the deal with the newly found popularity of 2-speed rears in today's trucks (I think I know the answer, I just want to hear it from someone else.)
- I guess what makes matters more confusing is that in the for-sale papers, every once in a while, an ad will say "twin screw" which I was under the impression ALL tandem-axle trucks were?
I know that to some these might sound like stupid questions, but at this point, I don't know, so I'm asking for an explanation of what's out there these days. Any help will be appreciated. Thanks!!
Question on differentials/power dividers and "2 speed rears"
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Hooda, Sep 2, 2012.
Yes.
Yes, but they don't work well for off road or extreme winter driving conditions.
They've always been popular in heavy haul off road applications with the need to crawl.
A "screw" is single drive axle, "twin screw" is two drive axles. Dead or tag axles don't count as drive axles. -
Yes correct, but conventional not referring to cab style.
Hello Hooda: Have a '00 KW with 52K 2 spd rears. 3.70 high range, 5.04 low range. Makes a good, versatile truck.
The disadvantage? Weight and $. -
I'll refrain from making this a "who's on first" conversation.
The upside to 2 speed rears is the following:
For guys who haul super loads grossing hundreds of thousands of pounds, they need very low ratios like 5:30, ratios that will not allow for legal highway speed when empty or lightly loaded. With a 2 speed diff, you can use the 5:30 for when your very heavy, and run say a 3:90 on the highway when your empty, allowing you to run the legally posted speed limit. These setups are expensive, more difficult to maintain, and very heavy, not something I would spec on a truck pulling less than 200,000 pounds. -
Either way, Heavy-Haul is where I would like to be in about 1-1/2 to 2 years. I figure that's how long it will take me to 1. actually get a job running flatbed. 2. Do that for a year, and, near the end of that year, start my move toward heavy haul. I live a short distance from 2 major heavy haul trucking firms (one is ATS-Anderson trucking), plus a bunch of smaller outfits. Then 3. Work my tail off to get the education and experience to be part of one of the "go-to" teams for the REAL big stuff, think windmill blades, bridge beams, skyscraper steel. THAT'S my ultimate goal. 650HP, pulling 12 or so axles......could happen, especially with the help of fine folks like you all in this forum -
Hooda:
If your refering to the Ebay ads from Great lakes diesel(or whatever name they go under now), RUN. I know of no one having good experience with them. There are many unhappy customers from there.
Do a search on GLD. You will see for yourself.
Goes back to the ole saying "if it sounds to good to be true..." -
550 or 600 hp with an 18 speed is a good combo . And you could do a tune to wake the engine up a little.
