Question on hooking up PS3/TV setup to inverter in sleeper
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Edmund, Oct 2, 2011.
  1. Edmund
    Edmund Light Load Member
    284
    80
    Aug 8, 2011
    Atlanta Georgia
    Pretty much what the title asks...What set ups are any of you drivers using and how is it set up.My trainers got a portable TV/DVD and his PS3 running off a 375 watt power inverter he bought from a Loves truckstop. The problem is every time him or I play it we'll get pretty far into a game then the #### TV scrssn goes blue or out. Don't know if its a inverter issue or the tv's junk.... inputs please...thanks
  3. Edmund
    284
    80
    Aug 8, 2011
    Atlanta Georgia
    Anything? And it happens while the trucks in opti-idle mode when the engine turns on and shuts off....:biggrin_2556:
  4. Beer Runner
    Beer Runner Medium Load Member
    544
    227
    Nov 2, 2010
    Canada
    I would say the TV is junk. For your own truck get an LCD TV, it takes less power to run, and set it up that way. Leave the CRT alone.
    Edmund Thanks this.
  5. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Most outlets will be disconnected when an engine is cranking over. So, when the engine starts to crank your inverter is basically shut off, thus anything connected will shut down.
    Mark
    Edmund Thanks this.
  6. justawheelholderfornow
    justawheelholderfornow Medium Load Member
    495
    105
    Oct 12, 2010
    The Bank
    I have a 23" Vizio LED, running off a 100w plug in inverter with NO issues. I have also had my laptop plugged into the inverter at the same time, again, with no hiccups.
    NEVER buy a TV/DVD combo!!
    One or the other will go out soon enough, and then what are you left with?
  7. Albert Wesker
    Albert Wesker Light Load Member
    69
    11
    Sep 17, 2011
    how many watts does your vizio use? mineis 19 inch and uses 25 watts and my 100w inverter wont work, as I tried it out yesterday it gives me sparks that I can see inside the vents in the inverter and a bit of smokes came out, and that 100w inverter is like that every time I plug in, even with nothing to plug in to the inverter to draw power from
  8. justawheelholderfornow
    495
    105
    Oct 12, 2010
    The Bank
    I already posted on that topic...your inverter is crap.
    It is supposedly a 65w draw
  9. Truckersmooth
    Truckersmooth Light Load Member
    103
    22
    Aug 24, 2011
    Denver, CO
    Yep sounds like your inverter is fried.. do not use it or attempt to use it unless you want your truck burned down.
  10. pji2100
    pji2100 Bobtail Member
    9
    Was it connected to the cig outlet? I bought a 400watt invert and it says anything over 150 watts needs to be direct connected to the battery. My ps3 won't start from the cig outlet . The invertor is fine cause other items work on it
  11. Alex-TundrA
    Alex-TundrA Bobtail Member
    7
    5
    Sep 26, 2012
    Canada
    180 watts is the most you will get from most cigarette lighter outlets because they provide 15 Amp power. Of course, that depends on the battery charge, but assuming the battery is at exactly 12V:
    12V x 15A = 180 Watts
    As far as I can see, a ps3 requires between 200 and 300W, depending on the model. TVs have a wide range of Watt requirements, just double-check the sticker at the back.
    pji2100 Thanks this.
