Question on Inverters (How they work)
Discussion in 'Questions From New Drivers' started by DDOC, Mar 9, 2014.
  1. DDOC
    DDOC Bobtail Member
    42
    22
    Aug 13, 2013
    While I am parked for the night and waiting to be loaded and unloaded, I would like to watch DVDs on my TV and maybe get in some gaming with my PS3. I was told I would need an inverter in my truck, I have never used one before. I take it that it is connected to the batteries and keeps things plugged up to it running while the truck is turned off. Is there a certain amount of time it before the batteries drain or do they run for a long time?
  3. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    There are 2 type of inverters. Small ones can plug into cigarette lighter and big ones need to be hard wired into truck and connected directly to batts.
    Inverters can power pretty much anythign you plug into a standard outlet. Depending on draw, you MAY get away with a cigarette lighter one. As for run time, it varries a lot based on what you have plugged in. If you do let your batts get low, just start the truck and charge um back up. PS3 does use a bit of power and if tv is on as well you probaly need a hard wired one. For large draws like microwaves and such, start the truck before you turn the micrwave on and leave it running untill your done.
  4. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Those inverters you need to talk to your company about.If they allow inverters then their shop installs them.If you go against company policy it could be grounds for termination if you get caught.The ones that plug into a cigarette lighter you can use and company wont say anything.Those are good for computers,dvd players and your cell.But for a tv,you'll need a bigger voltage inverter.
  5. DDOC
    DDOC Bobtail Member
    42
    22
    Aug 13, 2013
    Thanks for info and really thanks for the heads up pattyj. That would really suck to get fired over something like that. I would have spent maybe $150 and then got fired over it LOL
  6. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Some companies already have inverters installed in all their trks,the ones that come equipped with fridges.Then some allow high voltage inverters and some companies sale them,but if u was to buy one u would have to get it approved from the shop.
  7. happydad1204
    happydad1204 Bobtail Member
    I've also read about wiring your inverter into a set of jumper cables for a "temporary" hardwire for use with the higher voltage inverters.
  8. pattyj
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Forget all that bs reading,if they're not installed just right,inverters can start a fire,thats why the companies have policies concerning inverters.
  9. happydad1204
    A little common sense goes a long way with this too. Making sure to have the line fused properly with the proper amperage as well as ventilation for the unit will prevent a fire.
  10. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    A Cobra CPI 880 will work for what you want. It includes battery cables with alligator clips for portable use. Hook it up when you are sitting and run you a short extension cord.
    Another alternative is the CPI 480 which can plug into a cigarette lighter and run only the TV and game console. They both use maybe 300 watts max together.
    http://www.amazon.com/Cobra-CPI-880...15182&sr=8-1&keywords=cobra+800+watt+inverter
    http://www.amazon.com/Cobra-400-Wat...15372&sr=8-2&keywords=cobra+800+watt+inverter
  11. CondoCruiser
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    It doesn't take a rocket scientist to install one as long as you follow some simple rules. We know you're a girl! :biggrin_25522:
    Keep feed cables 4' and under. Run a short extension cord for additional length.
    The biggest concern to prevent fires... Protect the cables at the floor hole penetration with a rubber grommet and silicone to prevent the floor edge from rubbing holes in the cables.
    Use the correct size cables for the inverter. To make it easy the cable should be as big as the mount hole on the inverter, no smaller.
    Buy an inverter fuse which bolts straight to the battery post.
    Ground the inverter chassis to the truck chassis.
    That's for a permanent install. Follow that and you'll never have a problem.
