Question on permitted speeds
Discussion in 'Heavy Haul Trucking Forum' started by cburch21, Sep 28, 2020.
  1. cburch21
    cburch21 Bobtail Member
    10
    9
    Sep 20, 2020
    Permits and state provisions often state a max permitted speed limit for OD loads. Typically, it's somewhere around 55 mph. I often see OD drivers going the posted speed limit or much faster than the posted. My question is whether or not these rules are enforced and should I worry too much about going 60 in IL, where the permits & provisions say any overwidth loads are restricted to 5 mph above the minimum posted, which is about 45 mph on most IL interstates?
    truckdriver31 Thanks this.
  3. truckdriver31
    6,998
    8,360
    Sep 18, 2013
    it sure in the hail dont apply to them mobile home drivers. them some of the unsafest drivers i ever seen. js
    D.Tibbitt Thanks this.
  4. Rontonio
    Rontonio Road Train Member
    6,439
    47,382
    Aug 9, 2009
    Guess it depends on how spendy your permit was...get a $1000 permit pulled plus a ticket plus all the CSA hit and it might not be worth it to speed while permitted.
    Ca you do it, sure and get away with it probably but it will hurt if they choose to enforce ....
  5. chriskc
    chriskc Light Load Member
    173
    366
    Mar 31, 2013
    Kansas City mo
    I know Missouri is 10 under posted speed limit, but you only see the super loads doing it here around kc. Everyone else hauling OD loads will blow your doors off.
  6. black_dog106
    black_dog106 Road Train Member
    1,786
    1,666
    Mar 29, 2009
    MA
    Vermont, 50mph permit loads. Per coversation with DMV officer, they don't enforce speed restriction but use it to stop and check everything else.
    booley, truckdriver31 and cburch21 Thank this.
  7. Old Man
    Old Man Road Train Member
    4,597
    13,471
    Apr 3, 2009
    Oklahoma City, OK
    Missouri did away with the 10 under several years ago,Illinois has many speed rules, up to 10 wide can do speed limit down to 50 for super loads
  8. cke
    cke Road Train Member
    6,062
    74,697
    Aug 4, 2013
    Colfax Wi
    Michigan watches very closely
  9. kylefitzy
    kylefitzy Road Train Member
    4,727
    19,680
    Aug 12, 2007
    Kansas city,Mo
    Missouri has been the speed limit for a long time, at least on regular loads.
    blairandgretchen, D.Tibbitt and cke Thank this.
  10. kylefitzy
    4,727
    19,680
    Aug 12, 2007
    Kansas city,Mo
    That’s not what the provision sheet in Illinois says.
    SPEED: Maximum speed shall be 5 m.p.h. below the posted speed limit, EXCEPT when otherwise specified in the permit. Legal weight, legal height movements up to and including 10 feet wide are allowed to travel at the legal maximum speed limit.
    At 15’11” wide we often have this restriction:
    The maximum speed, except on highways with a minimum posted speed, in which case the speed shall not be more than 5 m.p.h. above the minimum posting, shall be 35 m.p.h.
  11. Landincoldfire
    Landincoldfire Heavy Load Member
    909
    4,976
    Sep 27, 2015
    New Holland, Pa
    At those speeds on any busy road. The rear escort fears for his life. But we gotta follow the rules.
    alds, blairandgretchen, booley and 4 others Thank this.
