Question on spread axle flat beds
Discussion in 'Questions From New Drivers' started by kaiwren986, Sep 6, 2008.
  1. kaiwren986
    kaiwren986 Light Load Member
    178
    55
    Aug 9, 2008
    Lowell, IN
    Heya,
    I've read alot about one of the hardest trailers to back being a spread axle. I see quite a few, and was wondering why that is, I have a theory, tell me if Im right :)
    I've seen them turn while unloaded and they tend to pivot on the forward axle, does that tend to be true while loaded as well? I really cant imagine it pivoting on the rear axle when loaded, but any insight is appreciated.
    Thanks
  3. 25(2)+2
    18,750
    45,501
    Sep 18, 2006
    the road less travelled
    If the rear axle is dumped, i.e. the airbags depressurized, it will pivot on the front axle, if the rear axle is aired up, it may pivot on either one, they don't back up the same way twice. The ideal setup is to be able to dump either one. If only one I would prefer dumping the front because that puts a bit more weight on the drive axles, and the back of the trailer can't swing as wildly. Loading affects turning in that more weight is on those tires, the trailers I pull are heavy empty or full, but the loads are pretty even, a normal flatbed load might be heavy at the front or the rear depending on what the load consists of. An even load is probably the hardest to back up while turning because both axles would tend to grab on uneven ground.
    The main reason for the dump valves is to save wear and tear on the tires, also saves strain on the whole trailer.
    Step decks have a short stub axle for each set of duals, they are probably the worst as far as being able to stand the strains involved.
    kaiwren986 and LightBulb Thank this.
  4. Brickman
    Brickman Trucker Forum STAFF Staff Member
    12,907
    12,209
    Sep 17, 2006
    WY
    This is the whole reason. If you are backing in on uneven ground then the pivot point changes on which axle is bearing the most weight.
    kaiwren986 Thanks this.
  5. MACK E-6
    49,023
    227,620
    I've always see the axles want to tear away from the frame on those spreadaxle trailers.
  6. Brickman
    12,907
    12,209
    Sep 17, 2006
    WY
    You would think so, but it happens a lot less than you might think. They sure take A LOT of abuse.
  7. kaiwren986
    178
    55
    Aug 9, 2008
    Lowell, IN
    Wow, didnt imagine there being so many factors, makes much more sense now, thank guys
  8. broncrider
    broncrider Road Train Member
    my personal opionon is if you have a spread, you NEED to have the dump valve wired to a switch inside the cab
    if you dont dump one axle in a tight turn (more than 45 degrees) you really scrub off rubber, and could possibly damage the suspension mounts
    not dumpin cuases alot of the odd tire wear on these trailers, and i see alot of them with an outside, manual dump......that the drivers never use.
    Working Class Patriot Thanks this.
  9. Ken Worth
    Ken Worth Medium Load Member
    639
    191
    Jun 29, 2008
    Great Plains
    If you turn too sharp with a lot of weight, the front trailer tires go sideways and tear the side walls. If you turn a sharp corner, it acts like a brake, especially when starting up hill. However, the spread allows you to put more weight on the trailer...40 thou compared to 34 for tandems... and is desiged to balance out the load so there's no more than 1,000 lb difference in axle weights.
  10. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    Then you have the whole lift axle scenario..... Let me confuse you a bit more..... How about these? :biggrin_25525:
  11. kaiwren986
    178
    55
    Aug 9, 2008
    Lowell, IN
    I see those alot in Gary :) I have seen them with most all of the axles lifted except a few towards the center[​IMG]
    Its just a toy but those are the ones I'd never want to drive, too much #### weight, I've seen them with 2 slabs of fresh steel being hauled down the road to be turned in to rolls, expensive tire bill no doubt.
