Question on the C15
Discussion in 'Trucks [ Eighteen Wheelers ]' started by stark21, Oct 24, 2011.
  1. stark21
    stark21 Light Load Member
    128
    5
    Jul 25, 2010
    Virginia Beach
    I have a 07 Pete 386 with a C15 475 13 sp. right now I am averaging 7.1 mpg.. if I were to flash the ecm to up the HP to around 500-550 would it gain more MPG.. also anyone now my my Torque is for that motor is. the prefix on engine is NXS..
    SHC Thanks this.
  3. rollin coal
    rollin coal Road Train Member
    13,483
    27,526
    Mar 29, 2008
    TN
    Is that hand calculated when you fill up, your rolling average? Or CAT ID numbers? What do you pull? If I got fuel mileage like that from mine I'd hesitate to make any kind of change but ordinarily, yes, upping the horsepower/torque will improve fuel mileage as long as you drive it right.
  4. stark21
    128
    5
    Jul 25, 2010
    Virginia Beach
    fuel mileage is calculated with the qualcom unit shows the performance I am getting with truck.. if I fill up I can get 2100 miles and there is still fuel left when I fill again. 150 gal tanks , I am leased onto schneider so the freight is heavy and light. heaviest load was 45900 and lightest was 5900.. I am pretty happy with the performance even with that 45900 I was able to pull decent size grades in the Northeast doing 60-55 up the hills so the motor can pull... I was just curious what the torque rating was.. didn't get a spec sheet..
  5. 07-379Pete
    07-379Pete Crusty Commando-Pete
    2,549
    2,347
    Oct 3, 2008
    Campbellsville, Ky
    I would say its a 1850 torque motor.
    And as far as your fuel mileage, if your truly getting 7.1 lets not try and get to greedy. With that kinda mpg I dont thing I would take a chance and muck it up.
    SHC Thanks this.
  6. stark21
    128
    5
    Jul 25, 2010
    Virginia Beach
    yeah your probably right.. so far everybody that I have told that I am getting that kind of fuel mpg thinks I am lying then I show them what the computer says and that's when you get wow and that's from cat motor.. just will leave it alone.. I thought it might be 1850 my series 60 was 1600 and this one out pulls that with no problem at all... love my cat
  7. SHC
    SHC Spoiled Rotten Brat O/O
    8,484
    7,047
    Feb 26, 2011
    Westville, IN
    I ran with SNI and my actual MPG was 1mpg LESS than the qualcomm. You are getting 6.1, not 7.1
    The computer only calculates when you are running, it does not factor in idle time and other factors. Actually try calculating your mileage between fill-ups and you will see.
    Also, if you are tired of the overspeed beeping at you, you will have to get the system turned off.
  8. pullingtrucker
    pullingtrucker Road Train Member
    1,185
    598
    Dec 21, 2008
    Fostoria, Ohio
    Also the qualcomm only tracks you when you cross "region lines" that are setup in the Qualcomm/SNI computer systems. I ran into this when I was very shortly leased to them. It really hurt me with my IFTA since I was running a lot of local stuff and never crossing the lines. But in realy life I was running 100-300 more miles a day than what their computers said.
    SHC Thanks this.
  9. belltransit
    belltransit Light Load Member
    271
    27
    Jun 28, 2010
    oak grove, mo
    if stark21 is gettin 6.1 or even 7.1 mpg out of a 475 c15 id love to know why i cant get out of the 5s with a c15 550. and lets not even talk about when the wind really gets to blowing. into the 4s when that happens.
  10. DL550CAT
    DL550CAT Road Train Member
    1,427
    1,482
    Oct 18, 2009
    Waynesburg, Pa
    I have a 06 W9 I am getting a true 6-6.5 mpgs. It is also a 05 mxs acert 18spd but with 3.55s. If I had 3.25 rears I think I would get better. Mine has been improved though with a PDI tune and a manifold. If I dorve with fuel on my mind I think I could get into the 7s pretty easy.
    SHC Thanks this.
  11. belltransit
    271
    27
    Jun 28, 2010
    oak grove, mo
    dl550cat we seem to have the same truck...mine was built in 1 of 06. its got an 05 mxs 550. the wife keeps track of the mpg and its averaging 5.2 right now. like i said when the wind picks up...forget it....its gotten down to 4.3 on the cat computer in the truck. i was truly hoping, when i traded for the truck, that it would get alot better than what its doin.
