question with check engine light
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by jeffl0123, Aug 24, 2022.
  1. jeffl0123
    jeffl0123 Light Load Member
    60
    14
    Jan 18, 2018
    Hey guys, need some advice what you think the issue could be. A while back, I had an issue with my truck stalled on me. I checked my filter and it was caked with black slimmy stuff. Figured out it had that bacteria in it as I had the problem a long time ago on another truck. Anyway, I put the killem biocide in there at the suggested dosage to kill the bacteria. It seems to have done the trick but about 2 weeks ago the check engine (yellow) light comes on. But as soon as you get the rpm's above about 1400, it will go out. Then as soon as it falls back below it comes back on again. I have changed my main filter about 10 times and it seems to be pretty clean right now. I also check and put a new filter in the fuel pump as well. Still the light comes on. Any suggestions as to why it could still be coming on? Its a 99 International 8100 with the Cummins M11.
  3. Mr Bob
    Mr Bob Light Load Member
    269
    84
    Mar 17, 2015
    gonna be a sensor hunt. sounds like it could be a fuel sensor so start there. unplug one of them and see what happens. then continue with the rest.
  4. bjytech
    bjytech Light Load Member
    244
    221
    Nov 9, 2013
    Only one way to really see what's going on and that is to find someone who can plug into it and run diagnostics, if the light came on there is a code stored in the ECM. Much cheaper than throwing parts at it.
    Goodysnap Thanks this.
