Questions about blocking the wastegate on 04 cat mbn
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Muddydog79, Feb 11, 2017.
  1. Muddydog79
    Muddydog79 Heavy Load Member
    820
    2,147
    Apr 14, 2016
    Whats the pros and cons of blocking the wastegate? Better power? Mpgs? Do you have to change shift points on uphill grades? Should i, or shouldnt i do this to my engine? Guess im asking what differences should i expect from my engine if i decide to block it?
  3. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    We used to do it all the time on our cats. Never did change how we drove just hung our foots off in it.
  4. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    I don't think it'll make much difference without a reflash. That being said you could put a small ball valve in line. That way you can fine tune it.
  5. Muddydog79
    820
    2,147
    Apr 14, 2016
    Reason i asked is Ive heard about doing it in almost every post ive read about the mbn, just not many replies on why, or what the pros are of doing. If it doesnt make much difference without the ecm flash, i think i will hold off untill it needs a rebuild to do the complete 6nz conversion. I have descent power now, and 5.2 to 5.8 Mpgs. Thats mostly driving using the eggshell theory. Just curious of any non costly upgrades that would help performance.
  6. strollinruss
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    That eggshell technique is the only way you'll ever get any mileage. I couldn't get 5.0 with mine, ever.
    joey8686 Thanks this.
  7. AModelCat
    155,247
    If you break out of the mid 4's on an MBN you're doing good.
  8. special-k
    1,523
    3,258
    Dec 27, 2008
    Afaik you can reflash it before doing the conversion. Theres a lot of them out there with just reflashes and no hard parts being changed.
  9. Oxbow
    Oxbow Road Train Member
    12,556
    129,153
    Nov 24, 2015
    I don't know all that much about this topic, but a couple of things come to mind:
    1) Why would an engine manufacturer put a waste gated turbo on an engine if it would get better performance using the same turbo without a waste gate?
    2) Building pressure causes heat. So if you are building more boost than your engine can use, and subsequently putting more heat into the intake after going through the after cooler, aren't' you actually hurting the performance? Cooler air is denser and therefore perhaps 150 degree air @ 20 psi boost is giving the engine more to work with than 180 degree air at 30 psi boost.
    I have a B model that I have a waste gated turbo off of an E model on. The reason is that the truck performs so much better while starting and shifting than the stock turbo did, with much less smoke, and way less turbo lag. Depending on the ambient air temperature my gate opens between 25 and 28 psi. With a stock turbo at my current fuel settings the most boost I would see was 25 ish. If I pinched off the waste gate hose I might get up to 35 or so pounds of boost I suppose, but the exhaust pressure would probably be at 40 or better to drive the turbo and the intake temperatures would also be quite a bit warmer. I just don't think that power and mileage would improve, except for the psychological aspect that I could say "I'm getting 35 pounds of boost!".
    I don't know the answers to any of this, but there is my two cents worth.
    SAR Thanks this.
  10. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,729
    Jan 30, 2010
    keep stroking.
    I think on the mbn, pinching of the waste gate will throw engine in a derate mode since the waste gate isn't controlled by the charge air side of turbo. If your serial# is a viable one all you need to do is reflash ecm and replace turbo with a 6nz and it will be a 6nz running purty cat.
    lester and Oxbow Thank this.
  11. Muddydog79
    820
    2,147
    Apr 14, 2016
    10-4 thanks for the replies. Only issue i do not like is the turbo doesnt fully kick in untill about 12 to 1300 rpms when on the high side of the splitter. Is this normal for a mbn?
