Questions about inspections
Discussion in 'Questions From New Drivers' started by Southpaw, Apr 2, 2009.
  1. Southpaw
    Southpaw Light Load Member
    64
    13
    Oct 12, 2008
    Robinson, Texas
    I've been doing some research on safestat scores and would like to know about how often you are inspected and how much time it takes, on average.
    All of the companies I have researched so far have scores that recommend inspection.
    If your company has a score of 75 or more do you get inspected every time you pass a scale house?
    Do you plan on being inspected and allow time for that when doing your trip planning?
    Has an inspection ever caused you to deliver late?
    I have read on some threads that drivers can expect to spend an hour or more for inspections. Is this a common occurance?
    Thank you
  3. larryh31
    larryh31 Light Load Member
    131
    72
    Jul 24, 2006
    Washington, DC 20032
    There are several different types of inspection. The most thorough is the Level 1 which will take about an hour to complete. Basically, the inspector will check your logs, license, etc. and do a complete inspection of your vehicle.
    http://www.dot.gov/affairs/cbtsip/inspchecklist.pdf
    The Level 3 is far more common, they will just go over your paperwork: drivers license, medical card, registration, insurance, bill of lading, etc., If everything is in proper order, you should be on your way in less than 10 minutes.
    Southpaw Thanks this.
  4. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    If a company has a history of vehicles OOS and an ISS-D INSPECT rating you will probably get a level 1 . If you are put OOS with a defect you'll be there a lot longer than an hour . Stay away from companies with INSPECT ratings .
  5. High Desert Dweller
    High Desert Dweller Medium Load Member
    431
    389
    Jan 29, 2009
    Checking a carrier's safestat score is an easy thing to do. It will give you an indication of how often you can expect to be pulled in for an inspection.
    Go to SafeStat and type in the USDOT# on the side of your truck:
    http://ai.fmcsa.dot.gov/SafeStat/SafeStatMain.asp?PageN=results
    Weigh station personnel use this system when you roll through a scale. Troopers also use it while patrolling the highways. They can grab your DOT# when passing you in the left lane, and get a quick rundown on your employer (and, indirectly, you) without you being aware of it.
    Shippers,brokers and insurance companies also check Safer scores to some degree. DAC/USIS will not do business with carriers who haven't had a recent in-office safety audit.
    If you're an independent, it's to your advantage to keep your operation high and tight. You should look forward to inspections. Good inspection results will lower your score, and benefit you in ways that aren't always apparent.
  6. RickG
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    When you get your company in click the ISS-D recommendation on the right .
    I have to question DAC/USIS not doing business with carriers that haven't had a recent audit . Many carriers haven't been audited for several years .
  7. High Desert Dweller
    431
    389
    Jan 29, 2009
    RickG, thank you for pointing that out. You may be correct regarding recent safety audits. When we inqiured about becoming a DAC subscriber, the declined us because our last safety audit was too old and didn't match our current physical address. More than likely, thay have a number of different things they check before accepting a new subscriber. I would imagine that their main concern is to preserve the integrity of driver backround data uploaded by member carriers.:):)
  8. Southpaw
    64
    13
    Oct 12, 2008
    Robinson, Texas
    Thanks to everyone for you helpful input.
    A company's safety rating is a concern in making my descion about who I want to work for. The problem I'm having is that there is a company that I am interested in but has had problems in the past. However, I have heard that they are working to improve their record so I am trying to take that into account because it will probably take some time for their score to reflect their efforts.
    Should I still stay away from them?
  9. RickG
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    Unless you have other options , take it . Jobs are hard to come by . Have they been audited lately ? Look at Crete . FMCSA came down heavy on them . Now they make sure they are compliant .
  10. Southpaw
    64
    13
    Oct 12, 2008
    Robinson, Texas
    Wow, I am really learning a lot, this forum is great! Wish I had this tool available back in the early 80's when I was first looking for driving jobs. But I don't think Al Gore had invented the internet yet.
    The last FMCSA Compliance Review was 9/30/05. I'm guessing then that there may still be some problems with them, right?
    Baack Thanks this.
  11. Southpaw
    64
    13
    Oct 12, 2008
    Robinson, Texas
    One more thing, when I went back to safestat to check the audit date I also went to the safer website. There, the carrier safety rating was listed as satisfactory. I'm a little confused about how the rating can be satisfactory yet the ISS-D recommendation calls for an inspect. What am I missing here? SafeStat score = 94, Safety Rating = satisfactory?
