Questions about older trucks.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Wildcat74, Jun 20, 2009.
  1. Wildcat74
    Wildcat74 Medium Load Member
    354
    128
    Jul 15, 2008
    Omaha, NE
    So I am OTR right now but I originally got into trucking with the intention of getting involved in the family construction biz (which operates in CA) with an end dump. Questions:
    Are the older engined trucks (big cam cummins, older detroits, 3406b's) going to be unusable with all of this emissions junk?
    Any retrofitting for said engines should the emissions issue arise in the future that would enable a truck with this motor to remain on the road?
    Which engine would you prefer as far as maintenance goes?
    Any advice you all can offer on older setups as far as what to stay away from or what you prefer would be appreciated! Thanks in advance!
    Adam
  3. 7mouths2feed
    7mouths2feed "Family Man"
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    Unfortunately CA is killing off anything that doesn't meet CARB its just a matter of exactly when. My understading is that the retrofits are going to cost way too much to be worthwhile.
    Wildcat74 Thanks this.
  4. Heavyd
    Heavyd Road Train Member
    7,812
    6,265
    Feb 4, 2009
    Yes, the old mechanical engines are dead! The emissions stuff for the new engines are causing enough problems as it is, let alone trying to retro them to old engines.
  5. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    Are the 3406E's and N14's going to make it or is it all going to be the C series and ISX/ISM's that are making the cut?
  6. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    alot of big company's are for this they know with low rates,the credit crunch and higher tax's o/op's wont be able to afford new trucks forcing the little guys out of buisness
  7. 7mouths2feed
    1,186
    464
    Nov 29, 2007
    Jacksonville, AR
    There are supposed to be requirements for retrofitting ALL engines that do not meet 2007 regulations look at CARBS site for more specific requirements and timelines.
    112racing let the big guys have Commy-fornia... I think everything should be dropped on the Nevada border or let them get everything from Mexico. Better yet give it back to Mexico.
  8. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    Something is going to have to give soon, CA is like a ticking time bomb for sure right now.
  9. Wildcat74
    354
    128
    Jul 15, 2008
    Omaha, NE
    It looks as though they are trying to implement these rules by 2014, the site mentions "aid available from the state of CA" :sign5: . From what I've been hearing about it now that I've been asking, the $$$ is going to be the states' biggest hang up, as many are claiming they are taking equipment (or the right to use equipment) while supplying no financial help that would supply no financial help in replacing this equipment.
    It's going to be interesting seeing how this all plays out because if it goes through the cost of goods in CA will go through the roof for the consumer, no way any biz owner can or will absorb these costs.
