Questions about orientation and inverters.
Discussion in 'PAM' started by jpchapman24, Jul 12, 2011.
  1. jpchapman24
    jpchapman24 Bobtail Member
    I have read some things that have me somewhat confused. I hopefully will be starting with PAM soon. Every other company that I drove for had orientation at their headquarters for two or three days, and then you are put with a trainer from the terminal or your house. Is it that way with PAM? Also, does PAM allow only inverters that their garage installs, or none at all?
  3. jezter5677
    jezter5677 Light Load Member
    145
    108
    Jun 11, 2009
    only inverters aloud are the ones with the 12v cigarette adapters, nothing hard wired in
  4. Noggin
    Noggin Road Train Member
    2,494
    977
    Apr 10, 2011
    Houston, TX
    You can go up to a 450w. anything else, take out before you go into a shop. ;)
    And with PAM, you go out with your trainer for a couple weeks, then depending on where you live, they'll set you up for orientation--which is basically finalizing all employment paperwork and such, and doing written, driving, and pre trip tests. then you get your truck, and they try to get you by the house within a short amount of time to get whatever else you need for your truck.
  5. Rollin2003
    Rollin2003 Light Load Member
    92
    33
    May 9, 2011
    You can always use the clips that come with the big inverters on the battery posts and then take them off when you're driving. If P.A.M. doesn't see it installed they will never know. They worry if you "hard wire" it you will fry the computer. I run two 400 watt inverters in my truck and it powers everything.
  6. jpchapman24
    Thanks, guys! I just found out that I'm starting on the 25th. My other half is driving me to AR. Which motel do they put me up in, and how bad is it? LOL
  7. djtrype
    djtrype Heavy Load Member
    935
    545
    Jan 3, 2009
    New Orleans
    If you have 6 years trucking, you shouldn't have to go with a trainer.
    If you're going for orientation in Tontitown, we have a "motel" on site. It's houses about 25 people. The rooms are tiny, but you should only be there a couple of days. It's dorm style, so you share bathroom facilities. Couple of restaurants in walking distance.
  8. Rollin2003
    92
    33
    May 9, 2011
    I dropped off a trainee at Tontitown three weeks ago and the Hotel PAM was full. If that happens they shuttle you to the Econolodge in the next town, and that day there were 2 shuttles full of drivers.
  9. cpm0487
    cpm0487 Bobtail Member
    17
    8
    Jun 16, 2011
    Canton, OH
    Be careful with the inverters! When i got my first truck it still had a 1500 watter that someone had left and PAM had somehow missed. I was excited, i got myself a coffee pot, microwave and a small toaster oven...then i found out when i put it in the shop that they were a no no, and it got ripped out and i never saw it again...bummer, lol. Maybe you'll get lucky and get yourself a truck with an APU that runs about 10% of the time...
  10. gravdigr
    gravdigr Road Train Member
    1,210
    1,121
    May 2, 2011
    Hollidaysburg, PA
    The problem with the high watt inverters is people do not install them correctly. They go and buy the install kit with the heavy guage cables advertised as having "everything you need to install an inverter up to 2,000 watts" but there is one very important component missing that anyone who has professionally installed car stereo amplifiers knows about....a fuse. With no fuse should your cable short out that heavy 4 gauge cable will get amazingly hot and catch fire anything touching it. I guess PAM had 1 too many trucks burn to the ground thanks to amateur installs like this and they ruined it for the rest of us.
    Also keep in mind most cigar lighter outlets max out at 30a...a 350w inverter at max load pulls 29a. Anything bigger and you risk blowing your fuses.
