How high are power lines and other utility lines suppose to be over a state or u.s. highway, for some reason I'm thinking 17 feet, please correct me if I'm wrong, thanks
Questions about power lines...
Discussion in 'Heavy Haul Trucking Forum' started by Shock Therapy, Mar 21, 2017.
Page 1 of 5
Depending on the gauge of the wire and the voltage traveling the wire.
When I was doing power plant construction. Heights ran from 11' to 18' above roads to buoldings.
It depends on your state.Shock Therapy Thanks this. -
Had a little mishap about three weeks ago involving a John Deere tractor, a very tall soil finisher and a cable tv supply line, when I got home today there was a nice little citation for being over height. Don't know how they knew if I was over height or not as no one measured the soil finisher...Big Don, snowman_w900 and Oxbow Thank this. -
NavigatorWife, Oxbow and Shock Therapy Thank this.
snowman_w900, Oxbow, Shock Therapy and 2 others Thank this.
NavigatorWife and Big Don Thank this.
Cab
You should know if you deserve that ticket. Were you legal height?
I just read your post again was this in Illinois. Illinois has some regulation in the oversize code, that farm implements don't need permits. I am not sure what size. It might only pertain to the wide. Not sure.
Worth a look.
Good luck.Big Don and Shock Therapy Thank this. -
We pulled it close to 100 miles and had one incident but I guess one is all it takes.
Big Don Thanks this. -
NavigatorWife, Big Don, Dye Guardian and 9 others Thank this.
When you measured - how tall were you?
The state or county or city can only conclude that you were outside the legal envelope based on your interactions with the utility's line.Ruthless, Oxbow and johndeere4020 Thank this.
Page 1 of 5
