Well, I am no newbie to driving, but a reefer unit is NOT something I am familiar with! But since the Boss jst bought a bunch of these things, I guess we are stuck with them.
Here's the question... It was cycling, and then it just jumped over to a "preheat" cycle, and then went back to cooling! No-one in the shop is familiar with them, and I certainly am not... What's going on here, and how do I fix it?
And where can I get some kind of manual on a thmo-king reefer?
Bonnie's Guy
Questions about reefer units...
Discussion in 'Questions From New Drivers' started by GuysLady, Dec 5, 2007.
http://www.thermoking.com/tk/index.asp
click productd then type of reefer and ya see specs and a few other thing hope this helps -
also ask refer tek in experienced truck thread
http://www.thetruckersreport.com/tr...ced-truckers-advice/31921-reefer-haulers.html -
Thanx!
Bonnie's Guy -
BTW, I am no HVAC (of reefer) expert, so I know some of my terminology is incorrect! -
Generally, that would be defrost mode. However, this could have been test mode. Did you just start it up?
Ice buildup will cause a reefer to throw on some heat to clear things out. This shouldn't take more than a few minutes. And is normal throughout the length of haul. -
From 80+ degrees to -10 . Yup, it's a wonderful thing to listen to for 2 days. -
It probably was just defrosting. OTOH, you could have a problem there. Make sure it is filled up with antifreeze/coolant.
I can't understand a company buying a "bunch" of reefers and not having anyone in the shop know ANYTHING about them. However it is a specialized field, and takes someone with the knowledge and the tools to repair them.
There are usually "contract mechanics" in any decent size area that specialize in this work.
You might take a look at: http://www.thetruckersreport.com/tr...ced-truckers-advice/31921-reefer-haulers.html in the experienced drivers forum.
