Questions about SuperService LLC
Discussion in 'Questions From New Drivers' started by carl99, Sep 13, 2011.
  1. carl99
    carl99 Bobtail Member
    St Clair, MI
    I have been checking out several companies to sign on with to get back on the road and this one seems to fit the short list. Can anyone give me some pro's and con's?
  3. chompi
    chompi Road Train Member
    5,653
    3,485
    Jun 21, 2008
    Deland, FL
    They are a sister company of Gainey, which is a pretty large company. Pretty sure their headquarters are up by you. Carl you are going to get every kind of good and bad answer probably more bad than good, about Super Service. What you need to do is check out their website then talk to a recruiter and decide for yourself if this particular company is going to best suit your needs. You are going to get out of it what you put into it. If you go into it being positive and have the will to work hard and hustle and be professional at the same time then you will most likely have a good experience. No matter what all companies have their good and bad points and every driver has their good and bad days. Patience is going to be one of your greatest assets and so is being able to deal with lots of stress.
    Good luck!
    SheepDog Thanks this.
