hey guys,
I'm a fairly new driver and have a few questions about winter driving, in particular about the operation of the truck etc.. I understand everything about safe overall driving habits, as far as slowing down, increasing following distance etc... but my questions are more about the truck itself...
For instance I drive a 2007 Kenworth T600... I'm sure not all of these are the same but i really don't know as much as I would like to about the truck, especially since its getting into winter now... I'm sure some of these questions will seem stupid etc... but I figure I'll never know for sure unless I ask, and I want to be as comfortable as I can to be as safe as I can... anyway...
1. This truck has the switch to lock both axles, when exactly is a good/bad time to use this diff. lock feature? also, is it safe to toggle this when moving? or only when stopped?
2. I also have a separete switch that says TC on it, which I assume is traction control, When is a good time to use this? and how does it differ from the diff lock?
3. I know not to use the jake brake in bad weather, so I'm assuming that its extra important to use a low enough gear, so that I won't have to be on the brakes too much, is this correct? if so, would the higher rpm of being in a low gear create a higher possiblity of the wheels spinning?
4. I don't know how to put chains on a vehicle, not even a car... I'm trying to read about it and watch you tube videos etc... my question is If I only have to chain one axle, how do I know which axle to chain on the tractor?
5. A lot is said about winter weather and truck driving but I dont hear much about how it affects backing? I'm pretty nervous about sliding if its slick when backing, since, of course, there is much less room for error than the typical room between vehicles you would get on the road etc... is there anything that should be done differently or avoided when backing in winter weather?
Thanks in advance for the help guys, I've been in a little weather so far this season in upstate NY and also in South Dakota, but nothing too bad yet... I'm in Montana now will be heading to Seattle for hometime in the next couple days, and trying to be prepared as I can in advance.
Questions about truck operation in winter, please help
Discussion in 'Experienced Truckers' Advice' started by pickinvet, Nov 24, 2011.
Page 1 of 3
Pretty new to driving myself (including winter driving) so I would be interested to hear the answers to your questions as well.
I can take a crack at number 1: I was told that it is bad for the truck to use the diff-lock at speed, for general use. I use it when I find myself spinning the tires on a bit of ice or whatever. I also understand that it is safe to engage/disengage whilst moving, just not when the tires are actively spinning out... -
My answers are in Bold /\
Good Luck, and be carefull.
American TruckerFratsit, volvodriver01 and buddy_bill Thank this. -
Thanks for the response, seems to make sense to me
GREAT QUESTIONS.....NEW GUY HERE ALSO...interested ,IN READING SOME ANSWERS ON THIS..SOON ..THANKS..
Don't use the dif lock while spinning out though. Toggle while moving, or stopped, but you will do some damage if one side is spinning and the other isn't and you hit it.
volvodriver01 Thanks this. -
1. The differential locks (different than the power divider lock) should typically only be used when either off-road, or in extremely slippery/low traction conditions on-road. When in use take greater care when cornering as the truck will be slow to respond as the locked differentials will push the truck straight. This can be especially bad on ice. If both diffs are locked and cornering is a problem, you can unlock the rear diff to turn, then re-lock when straight. IIRC, most manuals say to stay below 25-35 mph with the diffs locked. Some newer trucks will automatically disengage the diff locks over a certain speed. As mentioned, NEVER attempt to engage the diff locks while spinning out. You can dis/engage them when moving though, just let off the throttle a bit to assist the movement and then gently back on the throttle to continue.
The power divider (PDL) can generally be used at any speed, just follow the same instructions for dis/engaging as the diff locks, i.e., off the throttle then gently back on. I have driven for weeks at a time at all speeds both on- and off-road with the power divider in. In fact, if I feel it is getting a bit too slippery I will engage the power divider while rolling down the highway (often the reason I can maintain momentum and not have to stop and chain up
). It is recommended that it not be engaged on dry pavement however.
2. For most trucks the default position for traction control is ON, and the switch is to dis-engage it. This allows the wheels to spin which is actually preferred (within reason) under certain conditions such as mud, ice and snow. What you say... spinning is preferable? Yes. I'm not talking about grabbing three gears and bouncing off the rev limiter, I am talking about having the wheels move just slightly faster than the truck is moving. Sometimes when in mud, snow or on ice it is the only way you're going to move. Traction control usually works by either limiting engine power under a slipping condition, by applying the brake on the wheel that is slipping, or both. This can cause the truck to bog down and stop moving forward if TC is on. Normally when driving on-road you will leave the traction control engaged. Some trucks label the TC switch as OFF-ROAD.
3. I'm bad... I use the jake (and cruise) a lot of the time in crappy conditions.
A big truck diesel engine generates its maximum torque at low RPMs , eg. maximum torque in my current truck is at 1,200 RPM. That is when you are more likely to break traction.
4. I always chain the front drive (assuming the fifth wheel is more-or-less centred over the drives... which mine always is). It is usually a bit more of a PITA to do because of fenders, but the front drive has slightly better traction than the rear one (in part, that's why the tires on the front drive wear faster). Of course, when chaining you should also engage the PDL and possibly the diff locks if necessary.
5. Just be aware of the ground conditions, go slow and don't lock your brakes. The truck isn't going to suddenly take off on you, but do be aware that it can, and will, slide off steeply sloped or crowned roads/lanes, etc. If it is that slippery and you absolutely need to back there, then put down some sand or other traction aid first. Things to avoid? Other trucks and stationary objects.
volvodriver01 and Fratsit Thank this. -
First off, these are not dumb questions.
Power divider is an air control that "locks" your front and rear differentials together front to rear but not side to side like a posi unit. Look at the front of your rear differential where the short driveshaft goes into it. You will note a separate housing there. That's your power divider unit.
Some "extreme conditions" (logging,etc) have "locking" or "posi" rearends that may or may not have a cab control. These are the units that lock your axles side to side and makes the rearend work like a solid axle.
Traction Control on the newer trucks is an electronic, computer controlled unit with an electric switch on the dash. Works as previously described.
Power dividers can be engaged at any reasonable speed as long as you're going in a straight line, eg if you're approaching a hill you know is slippery. Never on a curve or when you've started spinning.
As to the backup on ice... watch especially close for pedestrians. Foot traffic can't get out of the way as quick as normal and might just slip and fall. Humans suck as traction aids.
thanks for the answers guys, i'm not sure If I have a diff lock, or power divider, its a switch on the kenworth that has a little pic/icon that looks like both axles... they tell to sometimes engage it when hooking to a trailer, how can i tell which one i have?
You likely have both. Power divider is normally a manual lever on the dash (usually on the bottom) right beside the ones for Air Slide 5th Wheel, Suspension Dump, etc. They go left to right and have a steel wire loop or cage over them to prevent accidental engagement.
Best thing I can tell you without seeing the truck is to check with your shop guys. Also have a look through the truck for an Operator's Manual. These typically wind up in a drawer or the bottom of a closet. They give a quite good explination of controls and how to use them.
Page 1 of 3
