questions about used APUS and fridge unit.
Discussion in 'Ask An Owner Operator' started by buddyvuk, Apr 14, 2013.
  1. buddyvuk
    buddyvuk Medium Load Member
    337
    66
    Jan 6, 2013
    portland oregon
    whats the best apu?
  3. critters
    critters <b>Late For Dinner</b>
    1,444
    2,440
    Jul 16, 2011
    traverse city,MI
    The price seams decent the hours too,I'd wanna hear it run and make sure it's all there.
    The fridge is possible to run when truck is off,just don't leave it for many days on end could drain batteries
    buddyvuk Thanks this.
  4. n1xrf
    n1xrf Light Load Member
    166
    32
    Jul 18, 2011
    somewhere in the USA
    It might be a good one. As for the powering a fridge with the truck off, you can power it on an inverter, and have your apu set on battery protect mode, so that it will run and recharge the trucks battery as the truck is off. I would want to make sure the apu actually runs before buying it.
  5. MJ1657
    MJ1657 Road Train Member
    7,521
    50,152
    Jan 28, 2012
    Isanti, MN
    My fridge will run about 3 to 4 days off of my batteries when my truck is parked during the summer time.
    I have one of those deals that cuts power off to my bunk when my batteries start running low.
  6. buddyvuk
    337
    66
    Jan 6, 2013
    portland oregon
    great advice. thank you
  7. buddyvuk
    337
    66
    Jan 6, 2013
    portland oregon
    thank you .
    MJ1657 Thanks this.
  8. buddyvuk
    337
    66
    Jan 6, 2013
    portland oregon
    yea , i am going tomorrow to check it out .
  9. CbarM
    CbarM Heavy Load Member
    894
    247
    Jan 17, 2011
    Irvine, AB
    The best APU is one involving a much cheaper gas genset, a window AC unit, and a space heater. Build a box for the genset and with the rest of the goodies thrown in you will have a good set up brand new for under 2 grand...
  10. spyder7723
    spyder7723 Road Train Member
    15,471
    25,076
    Mar 31, 2013
    sarasota, fl
    I got less than 650 total dollars invested in my apu. and about a dozen hours total install/ locating parts time. It's a 2 cylinder tk engine (made by Perkins) I picked up for 300 at a junk yard. 75 bucks for a used radiator and ac pump out of a Honda civic, 100 for heater/evaporator fan assembly out of a conversion van( the one in the rear). another 150 or so for all the belts/hoses/lines/fittings and angle iron to build the box/brackets and tie it all in. works great, only complaint is no generator for direct power so have to use a power inverter. also never did get around to figureing out how to get the auto start/ shut off wired in.
  11. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
    Best apu is your truck>>>>>>>>>>lol
