Questions on engine brake use.
Discussion in 'Questions From New Drivers' started by Woodys, Mar 16, 2018.
  1. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Yea machine shops can be bad too
  3. Fold_Moiler
    Fold_Moiler Road Train Member
    1,926
    3,529
    Mar 17, 2017
    In more ways than one lol.
  4. Bean Jr.
    Bean Jr. Road Train Member
    5,573
    9,929
    Mar 30, 2014
    That's why they have to use loud pipes!
  5. Bean Jr.
    5,573
    9,929
    Mar 30, 2014
    Clearly you do not know how a Jake works, or you would not say this. No combustion takes place that would raise the oil or coolant temperature.
  6. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,758
    Sep 20, 2014
    The compression does create heat, although not as much as combustion does.
    DougA and Bean Jr. Thank this.
  7. STexan
    STexan Road Train Member
    14,963
    29,160
    Oct 3, 2011
    Longview, TX
    Okay. If you say so. I guess the water and engine oil temp gauge rising and the engine fan activating on longer, steeper descents is just an odd coincidence and/or they're confused.
    :biggrin_25523:
  8. Bean Jr.
    5,573
    9,929
    Mar 30, 2014
    No more than just staying in gear without the Jake.
  9. ChaoSS
    3,338
    6,758
    Sep 20, 2014
    No. The friction will be the same, the compression that the Jakes use to slow the truck will create heat. That's just basic physics.
    DougA Thanks this.
  10. Bean Jr.
    5,573
    9,929
    Mar 30, 2014
    A truck in gear will generate the same compression. With the Jake on, the compression is released near TDC, with it off, the compression drives the piston down. If you want to say that on the power stroke, that the engine generating suction increases heat, perhaps you could share the physics behind that.
  11. Moose1958
    Moose1958 Road Train Member
    15,296
    33,965
    Dec 17, 2010
    Williesburg, Virignia
    Oh come on. We all know a jake slows a truck the same way Fred Flintstone stops his car.
