Questions-SLC Terminal
Discussion in 'Swift' started by HousTank, Nov 16, 2014.
  1. HousTank
    HousTank Medium Load Member
    622
    507
    Mar 17, 2014
    Houston, TX
    I'm getting conflicting info from my ECT.
    1. Has Swift shutdown the "old" terminal and moved all operations to the existing Central Refrigerated terminal?
    2. If YES, does anyone have the physical address of Centrals terminal?
    3. Is there a SIMULATOR there??..I need the winter driving session, getting nastygrams.
    Thanks All!!
  3. Moosetek13
    Moosetek13 Road Train Member
    14,656
    18,402
    Nov 1, 2010
    Burnsville, MN
    1. Yes.
    2. No idea, I don't. But I know how to get there. Don't be fooled by GPS directions, as you can only enter through the back door - and it is way, way around from the front.
    If it is your first time there you might be better to follow another Swift or Central truck in.
    3. Probably. Perhaps you might call them to ask the question directly?
    And when you call you could also get the address and directions.
    Just saying...
    HousTank Thanks this.
  4. Luse
    Luse Medium Load Member
    509
    627
    Nov 8, 2010
    Middle of nowhere Montana
    The addy to get to the gate is. 5305 W 2400 south England ct
  5. Moosetek13
    14,656
    18,402
    Nov 1, 2010
    Burnsville, MN
    The thing is...
    A current list of terminals should provide the correct information.
    That terminal has been in operation for nearly a year now.
    Getting directions should not be a problem!!!
  6. HousTank
    622
    507
    Mar 17, 2014
    Houston, TX
    Thanks for the above!
    You're right Moose..it shouldn't be a problem BUT I've been given by Swift staff various answers to the above questions. Including different addresses and phone numbers.
    They need to put and maintain an up to date list of all Swift terminals and Drop Yards on-line with accurate physical addresses and phone numbers. How hard can that be!?! Put a tab on the driver portal so if you're mobile you could quickly get to that info.
    The other night I tried calling El Paso..all numbers led to Phoenix and recordings and getting put on hold etc etc I gave up
  7. ironpony
    ironpony Road Train Member
    17,502
    12,015
    Sep 23, 2007
    Ask my GPS...
    Prime bought the old terminal. They need to burn it down and start over.
    PChase and HousTank Thank this.
  8. PChase
    PChase Road Train Member
    1,334
    613
    Sep 16, 2012
    Show Me State
    It's still a teaspoon better than the old terminal.
  9. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    At the very least, if you put the address code number in the Qualcomm navigation it should route you correctly. However my one year old reference book instead routed me to the old terminal. That should be updated.
  10. NoBluffBuff
    NoBluffBuff Light Load Member
    193
    87
    Apr 4, 2012
    Northern Idaho
    What does "73 to all" supposed to mean in your signature, PChase?
  11. Luse
    509
    627
    Nov 8, 2010
    it means best regards
    Just be glade it's not 88 to all
