quick HOS question...
Discussion in 'Questions From New Drivers' started by davis422, Aug 28, 2011.
  1. davis422
    davis422 Bobtail Member
    18
    Aug 27, 2011
    omaha, ne
    If I sit at a repair shop for 10 hours after 1 hour driving, can I just mark this time as Off Duty, or does it have to be on duty not driving? I guess I could just put sleeper, since thats what I did all day. Maybe I answered my own question.
  3. aggie1978
    aggie1978 Light Load Member
    165
    85
    Mar 16, 2008
    Jackson, MI
    log it in the sleeper. you got a 10 and start running for as long as your body will let you.
  4. NYROADIE
    NYROADIE Heavy Load Member
    773
    471
    Jun 24, 2010
    Rochester NY
    Log it off duty, and make sure you do have some of the time at the shop as on duty. Don't log it as sleeper time, Why lie about it? Line 1 or line 2 counts the same for a 10hr break.
  5. davis422
    18
    Aug 27, 2011
    omaha, ne
    how is it lying if I spent the entire time in the sleeper basically?
  6. 123456
    123456 Road Train Member
    10,555
    5,747
    Oct 22, 2010
    32179
    :biggrin_2559:
    There is NO such thing,
    as a quick question around here !!!!!!!!!
    BigJohn54 Thanks this.
  7. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    It isn't lying to log it all as sleeper if that's where you were. There is no requirement to be actually sleeping. Even if you broke it all up as off duty, sleeper, off duty, etc, it all means a 10 hr break. It could be argued that one should show a few minutes on duty to reflect turning the truck into the shop, I never do it. Your call on that one.
  8. Allow Me.
    10,687
    12,271
    May 28, 2009
    Rancho Mirage, Ca.
    I'd go "off duty". Being in the sleeper while Mikey the mechanic is working on your truck isn't likely. Mechanics don't want to be bothered by drivers climbing in and out or possibly hitting the start switch. Just working underneath and having a driver rolling around the bunk might shake some debris into the mechanics eyes. Plus, how else can they take 10 hours to do a 3 hour job if the driver is nearby, lurking ?
  9. davis422
    18
    Aug 27, 2011
    omaha, ne
    the trailer was disconnected in the shop.. the tractor was in the parking lot.
  10. Yatista
    Yatista Medium Load Member
    479
    206
    Jan 25, 2009
    Upstate New York
    Log the time you were in the sleeper on line 2, log the time you weren't in the sleeper eating, exercising, and sight seeing as off duty. Log what you did. Do you have authorization from your company to log off duty?
  11. gravdigr
    gravdigr Road Train Member
    1,210
    1,121
    May 2, 2011
    Hollidaysburg, PA
    I have slept in my truck many times while it was in the shop. When my dash wiring harness caught fire (long story) after 10 1/2 hours straight driving I told the mechanic at the T/A I needed sleep and he said no prob. I slept in the back with the curtain pulled while they tore my dash apart and repaired the wire harness. I also slept in the back at a freightliner while they replaced my a/c compressor. They really don't care as long as you aren't jumping in and out 10 times an hour.
