Quick Inverter watts/fuse question
Discussion in 'Ask An Owner Operator' started by dztruck, Mar 16, 2020.
  1. dztruck
    dztruck Light Load Member
    271
    208
    Feb 22, 2017
    Hi guys, im getting a 3000w pure sine wave inverter in the truck finally. What size fuse is recommended? Ive heard 10% of the max watts. So 300amps should be ok.
    the other question i have is the the inverter says 6000w peak surge. Does that mean it will blow a fuse if it has to surge for somethhing? Would that mean i would need a 600amps? Sorry if its a dumb question i havent installed an inverter before. Thanks. Be safe.
  3. HoneyBadger67
    2,056
    4,512
    Dec 15, 2018
    Savannah, TN
    'Peak surge' is when you start an electric motor that requires more power to start than run. For the longevity of your inverter, you should probably never come close to the peak. Try to keep all of your appliances to around 2500w total to allow room for startup if you run more than one at a time. Your refrigerator and/or toaster oven are two appliances that require more power to start than run.
    86scotty Thanks this.
  4. Ridgeline
    22,436
    116,921
    Inductive loads don't have a startup current as does motors and microwaves.
    HoneyBadger67 Thanks this.
  5. Wombat63
    Wombat63 Light Load Member
    90
    57
    Nov 3, 2018
    I installed a 3000W pure sine inverter in my truck over a year ago and have been using a 500amp fuse, haven't had any issues with it. I run a dorm size fridge freezer, microwave, TV, heated blanket, coffee maker -- obviously not at the same time -... the only thing I do is I have my fridge plugged into a surge bar with an on/off switch and when I'm using the coffee maker I turn the fridge off while its brewing, (It could probably handle without turning it off) just in case it cycles while the coffee pot is brewing.
  6. abyliks
    abyliks Road Train Member
    3,913
    9,156
    May 2, 2010
    ludlow MA
    I have a 250w circus breaker mounted in the battery box
