Quick n Easy truck stop backing question
Discussion in 'Questions From New Drivers' started by Audiomaker, May 17, 2016.
  1. Audiomaker
    Audiomaker Light Load Member
    177
    104
    May 25, 2014
    Portland, Oregon
    I've spent a lot of time at truck stops all over the country and watched with anxiety while countless drivers try to back their trailers into parking spots where they just barely have room to cut the whole rig in without hitting the truck in front of them.
    "How Stupid this truck stop didn't make this lot another 20' wide!" I'd think to myself.
    Then one evening it came to me that the truck stop was probably built prior to '53 trailers when there were only 48' and under.
    Is this the correct reasoning?
  3. HalpinUout
    HalpinUout Road Train Member
    7,074
    18,165
    Oct 2, 2011
    A lot of the truck stops especially the pilots and Loves have been built in recent times with 53 foot trailers.. They want to squeeze as many trucks in a possible and don't care how long it takes someone to get into a spot.
    Lepton1, hunted, Longarm and 2 others Thank this.
  4. Hoofbeats
    Hoofbeats Road Train Member
    1,250
    1,991
    Jan 27, 2010
    Iraq
    A lot of the older ones, the non brand name ones, were built before 53' trailers. A lot of zoning laws limit the amount of trucks allowed at some truck stops so they try to squeeze as many in as possible.
    Audiomaker Thanks this.
  5. CJndaTruck
    CJndaTruck Road Train Member
    3,349
    3,365
    Nov 21, 2014
    Knoxville, TN (area)
    Yes you are thinking right. People forget that most truck stops out there are just rebranded older truck stops. Walk into many TAs and you can find a photo from the 50s or 60s of it. As older truck stops get bought out by the Megas they seem not to make many changes. Go to a new loves and you will find more room and bigger spaces. This is because most loves are built much more recently.
    Lepton1 and Audiomaker Thank this.
  6. Hoofbeats
    1,250
    1,991
    Jan 27, 2010
    Iraq
    A lot of the old TAs were old 76s. Truck Stops of America wasn't founded until 1972.
  7. RustyBolt
    RustyBolt Road Train Member
    2,073
    3,333
    Feb 21, 2015
    Bement, IL
    You also need to keep in mind that the parking lots of newer truck stops are designed by engineers that have never even sat in a truck. Let alone backed one into a space at 3am.
  8. skellr
    skellr Road Train Member
    8,737
    12,187
    Jul 17, 2011
    The Village, Portmeirion
    Loves is still putting them in with blindside parking... Winners there.
  9. Bean Jr.
    Bean Jr. Road Train Member
    5,504
    9,788
    Mar 30, 2014
    TA/Petro are known to be easier to park than Pilots or Loves. Just because the truckstop has been there since the sixties, doesn't mean they haven't rearranged the lot.
    Loves on the other hand are built that way. Small lot, tight spots.
    HalpinUout Thanks this.
  10. Redtwin
    Redtwin Road Train Member
    5,487
    7,608
    Aug 17, 2012
    PBC, FL
    It's not just truck stops. Im at a rest area on I10 and the parking spaces were laid out by someone who has never even seen a truck never mund sat in one.
    Its a weird herringbone type layout where if you pull into the spot far enough to let a truck get vy behind you it means your hood sticks out too far in front so trucks struggle to get by in front.
    I am just hoping the truck right beside me leaves before I do or am going to have to mount the curb to make the turn past him.
    Lepton1 Thanks this.
  11. Blackshack46
    Blackshack46 Road Train Member
    Ummm, a lot of what we do in life was designed by someone we don't know, and made by someone we never thought existed and neither of them use or know what they just built.
    So I disagree that it is the truck stop engineers fault. I think as a professional in an ever changing industry, we should adapt and overcome the circumstances in which we have no control.
    Or we can just go back to #####ing about toilet paper holders and why they don't have directions with arrows for placement.
