R-14 leaking with button out
Discussion in 'Trucks [ Eighteen Wheelers ]' started by bowtieboy77, Feb 9, 2014.
  1. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    I believe I know the answer to this just looking for second opinions. The r-14 relay valve will leak all air out bottom exhaust port and will drain the secondary air when the parking brakes are applied (button out) I have seen lots of them leak with brakes released usually caused by a back feeding brake chamber. I believe it is just a defective r-14 valve however it was just replaced not long ago. System works fine when brakes are released.
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Ck. if it was replaced with a china made valve, most wont last long.
