R&R N14 main bearings . How difficult?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rocky64, Feb 4, 2014.
  1. Rocky64
    Rocky64 Medium Load Member
    358
    137
    Oct 3, 2010
    Greater Chattanooga
    I've read on several occasions that it's advised to change out the main bearings on an N14 at 600-700k to extend the life of the engine. So without me saying that I should or shouldn't, if I were to pay for that job, how many hours would it likely pay/take... and given my slightly above average (but by no means expert) aptitude can this be done in the garage behind the house on a Saturday with little help?
    Thanks
  3. Eustace
    Eustace Bobtail Member
    47
    12
    Jan 28, 2014
    For starters, I like youre quote, makes me laugh. Yes you can change bearings in a n-14 in the garage behind the house, but beware, these main bearings are not like any other bearings you may have changed before in anything else, it is a process that takes getting used to because you have to lock the lower bearing into the "wedding band" before you install lower cap, once you master that you will be fine, if you start truck and it runs long enough to build air pressure you have a winner. Good luck.
  4. Rocky64
    358
    137
    Oct 3, 2010
    Greater Chattanooga
    There is a well respected diesel mechanic in the neighborhood. He does side wor kK. How much would this job reasonably cost for a well seasoned veteran to do on a weekend project? Any ideas? I'm thinking of asking him, but I want an idea first.
    Additionally, any online ssites where I might procur these parts necessary for this job?
  5. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Not a hard job . But the back yard in is not very clean . You want to keep inside as clean as you can. You will need a good large torque wrench. Do not just change mains , feed it rod bearings when you do or have it done.
  6. Rocky64
    358
    137
    Oct 3, 2010
    Greater Chattanooga
    Sounds like I will pay to have it done. The guy is reputable so I guess he will be fair. Maybe he wI'll be able to get the parts. Oil pan gasket, mains, rods.... Oil pump? Should he/ I do it while I'm /he's down there (thinking small block Chevy)...
  7. D389
    D389 Light Load Member
    99
    56
    Mar 24, 2013
    Texas Panhandle
    I want to say it was somewhere between $600-850 when the n-14 at work had rods and mains done. I'm not 100% sure but it was in that neighborhood. I thought it was pretty reasonable.
  8. bowtieboy77
    bowtieboy77 Light Load Member
    274
    82
    Aug 16, 2013
    Southern, Ontario
    I would not worry about oil pump I rarely have seen them fail. If you have decent pressure now you'll have even better pressure after. As far as time goes your probly looking at around 6-8 hrs for the whole job rod and mains and pan reinstall. Of course this will depend on how many beers you give him during the job lol.
  9. Rocky64
    358
    137
    Oct 3, 2010
    Greater Chattanooga
    Im going to ask the mechanic if I can help, ummm watch. Maybe throw a hunnard doller bill in for the trouble. I just want to learn about my truck without running everything.
    wore out Thanks this.
  10. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I didn't do mine until 1.3 mill. miles, and they were not that bad. The only reason we did it was because I had low oil pressure. After installation of new bearings, still low. Finally found loose wire going to oil pressure gauge.
    I have 1.6 mm on the engine now, with no inframe. Neighbor has 18 trucks, all Cummins, 2 of the older trucks are N-14. One has 1.7mm, and the other 1.6mm, neither have an inframe.
    So, if the truck has good pressure and was taken care of, I wouldn't bother at 6-700,000 miles.
  11. Rocky64
    358
    137
    Oct 3, 2010
    Greater Chattanooga
    Bakerman, this is good information. I'm only privy to how it's been kept for the last 300k. Good honest hard wo rking family outfit has kept it up well. They seem to think it won't need anything major, if I maintain it, for a couple more years. I've read a lot and it's given me an idea that rods and mains would be a good ppreventative measure. I'm easy on a truck and usually over cautious with everything that might cost me more later.... Thanks for your advice.
