R&T Transport Inc Very bad company
Discussion in 'Report A BAD Trucking Company Here' started by g.o.a.l, Feb 28, 2013.
  1. g.o.a.l
    g.o.a.l Bobtail Member
    18
    4
    Sep 5, 2012
    Lincoln,Nebraska
    Thought all should know that R&T Transport out of Cook Nebraska and also Tecumseh Nebraska are bad news. Your dispatcher will never answer the phone to you or a repair shop,simple breakdowns i.e blown tires and such take a minimum of 24hrs for repair bill to be paid. The equipment is in such disrepair that every scale that you come across will put u out of service,( fuel leaks,exhast leaks, air leaks, turbo gasket so far gone that all the exhused was being pushed in the the cab thru the air filter,etc) In a 14 day period I was out of service twice by dot and broke down while under a load everyday for 11 days. Then after all of the brake downs I was told that there was no money for fuel so I was going to have to wait 3 days on less than a 1/4 tank of fuel in below zero temps ands not to idel and no motel room while I waited. In the end due to no fuel money and the truck gelling up on the way to their yard so the truck could be looked at by there so called mechanic, I parked the truck and had to pay out of my own pocket to fuel and get the thing ungelled and after all that expense the owner shows up and takes my keys and says I abandoned his equipment and I'm fired. Real bad news from start to finish.
  3. Trucail
    Trucail Medium Load Member
    611
    294
    Oct 27, 2011
    Seattle, WA
    That is a major law suit. Hope you have documentation.
    g.o.a.l Thanks this.
  4. g.o.a.l
    18
    4
    Sep 5, 2012
    Lincoln,Nebraska
    I have all of the documents related to the break downs and all communication related to shop payments loads ran and the pay for it yourself not my problem to. Wasn't sure about the law suit part but thanks for the heads up
  5. muledriver
    muledriver Light Load Member
    270
    128
    Aug 8, 2012
    I would be disputeing that dac report and calling a lawyer asap .
