Radiator leaking
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Greg5915, Mar 9, 2016.
  1. Greg5915
    Greg5915 Bobtail Member
    6
    Can i do anything to fix this problem or do i have to replace
  3. Pedigreed Bulldog
    7,737
    14,422
    May 7, 2011
    I soldered cracks in my copper/brass radiator seemingly every week or two until I got around to replacing it. Had 2 "new" copper/brass radiators replaced under warranty (less than 1 year old) before saying F it and buying a heavy duty Aluminum one. Got mine from CG&J in Gadsden, AL and been problem-free ever since.
    So sure, you could solder cracks, fill holes, and fill it up with various stop-leaks...but the best and only sure-fire way to FIX it is a new radiator.
    taxihacker66 and strollinruss Thank this.
  4. Smellfunny
    Smellfunny Road Train Member
    1,446
    967
    Jan 28, 2012
    South Carolina
    A little more info. What kind of truck? Where is it leaking (core?, end plates? Plastic or metal end plates?) How big of a leak?
  5. Diesel Dave
    9,281
    29,747
    Jan 20, 2010
    Hesperia, Ca.
    The last time my radiator was leaking, it was from the gasket, upper tank. I figured easy fix. I pulled the radiator out, sent it to the shop, $1100.00 later, had a new core in it. When they took the old one apart, they said it was ready to stretch like and accordian. With the horsepower I had, they did me a favor, upgraded to a 5 row.
  6. Greg5915
    6
    Kenworth t700, cummins, plastic endplates.
    Not a big leak.
    Small puddle underneath on the driver side
  7. Smellfunny
    1,446
    967
    Jan 28, 2012
    South Carolina
    If the leak isn't to bad then you could try this. Plastic endplates suck. If you end up replacing then try and get a new unit with metal endplates.
    http://www.amazon.com/K-Seal-ST5516-Purpose-Permanent-Coolant/dp/B002BJEG3U/ref=pd_sim_263_2?ie=UTF8&dpID=41P2iZDOeML&dpSrc=sims&preST=_AC_UL160_SR124,160_&refRID=1D2YDCZ9Z2HA0128BMPX
    This is some pretty good stuff. I have used it with guys that have leaks on plastic end radiators that did not have the funds to replace and it stopped most of them.
    BoxCarKidd and taxihacker66 Thank this.
