radio disconnect
Discussion in 'Questions From New Drivers' started by big rig newbie, Jan 18, 2013.
  1. big rig newbie
    big rig newbie Bobtail Member
    I have 2013 international prostar I want to make radio stop working it's a long story maybe a fuse or something could do this?
  3. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    Try the off button.
    larry_minn and Tonythetruckerdude Thank this.
  4. interdude
    interdude Light Load Member
    171
    74
    Mar 28, 2012
    prob doesn't work & makes a racket
  5. Jumbo
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    That isnt a long story..........
  6. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    His co-driver has different tastes in listening preferences, no doubt and/or listens way too loud. You need to find someone else to team or train with because a bad fuse is only a very temporary "solution" at best. But I can sympathize if that's the case.
  7. dpwelsher
    dpwelsher Light Load Member
    56
    13
    Feb 28, 2012
    Greater Chicagoland Area
  8. larry_minn
    larry_minn Light Load Member
    199
    177
    Nov 15, 2012
    Minnesota.
    I assume co driver's music choice/volume is issue? Person driving decides station, volume to (some extent) (exception if owner is one driver) :)
    You need to work together. Volume down if one is sleeping... (maybe look at ear muffs?) Relocate speakers so only driver gets direct sound?
  9. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    Stun gun!
    Or pull it out and pull the power wire...
    Mikeeee
  10. Jumbo
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    If it is something to do with radio control or volume then wouldnt the grown up thing to do be to talk it over with the other driver?
  11. Chinatown
    Chinatown Road Train Member
    74,924
    170,779
    Aug 28, 2011
    Henderson, NV & Orient
    Cut the wires to the speakers in the sleeper birth. Cut a couple of inches off so it can't easily be reconnected.
