Radio Power Problem
Discussion in 'CB Radio Forum' started by thetez, Aug 5, 2007.
  1. thetez
    thetez Medium Load Member
    380
    24
    Jul 10, 2006
    i had my pickup off the road for a while... i had taken the CB radio out of it. After i put the truck back on the road i reinstalled my CB radio. I can turn it on, and it will show the display.
    Now the problem is that the reception meter lights don't show any activity, not even if i key the mic, i can play with the squelch and it makes no difference, not even the static white noise stuff. i was wondering if anyone here thinks its my radio... or my antenna.... i just ordered a new antenna system haven't gotten it yet. but would a problem in the antenna make this problem for me... im hoping so so i dont have to buy a new radio... i really dont have the money for that.
  3. Bullwinkle
    Bullwinkle Medium Load Member
    594
    29
    Jun 11, 2006
    Texas
    Possible broken antenna cable, or disconnected antenna cable.
  4. 2xR
    2xR Medium Load Member
    365
    94
    Dec 12, 2006
    Ol' North State
    It sounds (or not <pun intended>) like you've lost the antenna connection. Sometimes when I'm relocating my stuff into a different truck, I'll forget to turn off the radio. When I plug in the power wire, prior to connecting the antenna, everything lights up, but, all I get is dead air. When I screw the coax into the back of the radio, the racket come to life.
  5. thetez
    380
    24
    Jul 10, 2006
    my antenna is screwed in... ive unscrewed and plugged it in a few times to add an SWR meter into the line....
  6. Bullwinkle
    594
    29
    Jun 11, 2006
    Texas
    Well, if you have checked SWR's, then that eliminates a break in the antenna cable somewhere.
    Anything else would be a pure guess, so I can't help any further. I have seen bad mic's cause this.
  7. thetez
    380
    24
    Jul 10, 2006
    i had only TRIED to test the SWR, their was no reading what so ever.... its not like i got a reading... i just really hope my new antenna system fixes it... if not looks like ill be getting a new CB ... with the money i dont have
  8. Carolina Thunder
    Carolina Thunder Medium Load Member
    584
    179
    Jan 28, 2007
    Coeburn V.A.
    A blown final will cause this.
  9. Twocycle
    Twocycle <strong>Road Apple</strong>
    I would try another mike for your radio. I don't think it's the antenna. If there is a broken wire in your mike cord it will do what you're experiencing.
  10. thetez
    380
    24
    Jul 10, 2006
    Thanks, i will try that.... if i can find a mic for it .... its a 5 pin ... in an arch type shape.... i need to find one before i can try it
  11. BobC
    BobC Medium Load Member
    409
    58
    Jul 8, 2007
    Cincinnati, slOhio
    You never mentioned what brand or model of radio you have.
    Most of todays radios will allow the receiver to operate but the speaker won't be active without the mic. You should still see receive indications on your S meter even though the speaker doesn't make a sound w/o the mic.
    A few older radios required the mic plugged in before the receiver was given power to operate. I doubt you have a radio like that but one never knows.
    The issue is that your transmitter isn't coming on as well as no receive indication on the meter.
    The one thing that can cause both the receiver & the transmitter to fail simultaneously is the PLL (phase locked loop) section of the radio.
    This is the circuit that receives its instructions from the channel selector & converts that info into the channel to listen & talk on.
    If this is the culprit, it shouldn't be too expensive to repair unless the parts are obsolete. It might even be that someone mistuned the pll adjustment coil to where it was on the edge of working/not working at a certain temperature. It can be that critical on the very edge of operation. The fix, of course, is to readjust it to the proper setting.
    Another common failure in the pll section is the crystal used in the reference oscillator section. It can be damaged thru age &/or sudden sharp vibration (like dropping or banging the radio). These crystals are easily scrounged from a parts radio or new from the parts suppliers. Last I recall, the cost new was maybe 5-10 bucks.
    One more item of common failure is the voltage regulator IC or diode that keeps the voltage to the pll very steady. If these fail, the pll either gets no voltage or not enough to run on. The IC's might run 5-10 bucks, the diode typically runs under a dollar.
    These prices don't include the installation & actual service time to see what's wrong.
    Lastly, there's a handfull of little things that might be wrong. A bad solder connection, cracked printed circuit board, a shorted capacitor etc etc.
    Except for the cracked pcb, none of these are hard to fix.
    Hope this helped some.
    As a PS, make sure the radio isn't in the PA mode or weather mode.
