Radio Stopped working .. also the cigarette lighter on the front dash?
Discussion in 'Volvo Forum' started by JerryD13, Feb 27, 2017.
  1. JerryD13
    JerryD13 Light Load Member
    169
    126
    Oct 17, 2016
    For Volvo 670 - 2012
    Radio Stopped working .. also the cigarette lighter on the front dash?Radio Stopped working .. also the cigarette lighter on the front dash? -
    The radio is out - no lights nothing -
    I was looking to see where the Fuse numbers are - and can not find.
    *** any feedback would be appreciated - Thanks in Advance !!!
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Should be in the back of the fuse panel cover most likely u burned the radio or lighter fuse maybe both
    Doealex Thanks this.
  4. DUNE-T
    DUNE-T Road Train Member
    6,979
    16,936
    May 10, 2015
    Detroit, MI
    Fuses and just in case also check black ignition relays in fuse box panel, switch them up.Might not fix the cigarette lighter, but should fix the radio.
    I had a weird problem on my Volvo. When it was raining, left power window and radio would intermittently cut off. One day they just completely stopped working.
    I was going nuts trying to figure out the problem, even replaced the ignition switch. Ended up on of the relays went bad
    JerryD13 Thanks this.
  5. JerryD13
    169
    126
    Oct 17, 2016
    Very Interesting - Thanks I will change these "Black Ignition Relays" out !!
    Thanks Again!
  6. Aradrox
    Aradrox Heavy Load Member
    900
    622
    Jan 21, 2016
    Kick it yet? Always works for me
  7. LasonyaFeltus
    LasonyaFeltus Bobtail Member
    2008 hino cigarette lighter want work..I don't know which fuse to check
  8. Doealex
    Doealex Medium Load Member
    597
    1,132
    Feb 21, 2018
    Just check them all. You don’t need to pull the fuse to check it. Any cheap ohmmeter will work
