Ran over semi tire and broke my air lines. FML
Discussion in 'Ask An Owner Operator' started by Siinman, Mar 16, 2022.
  1. Siinman
    Siinman Road Train Member
    5,289
    13,391
    Mar 5, 2017
    Kansas City, MO.
    So driving in ungodly traffic and out of now where in the 2-3 lane is a blown semi tire. I was turning into the lane as it popped out of no where and ran it over with the trailer. Ended up busting my air lines and electric line. Brakes come on and ruin my nice 1 year old tires.
    Only good news is I had enough fittings and connectors to put it back together until I can get it fixed. Hopefully tomorrow the utility shop down the road from where I am heading is able to get me in and fixed right. I don’t think I can slide tandoms as it is set up now.
    D.Tibbitt, buddyd157, Coffey and 5 others Thank this.
  3. Phantom307
    Phantom307 Light Load Member
    222
    210
    Jul 5, 2019
    Cheyenne
    Word of advice, if those tires aren’t round anymore I think it’s doing more damage to the suspension and other components to run em like that with all the vibration. I had a similar situation and I chose to be cheap and it cost me. Some things rattled loose on the leaf springs and brakes and ended up costing me money. Nothing too serious but I think if I hadn’t caught it in time it could’ve been worse.
  4. Siinman
    5,289
    13,391
    Mar 5, 2017
    Kansas City, MO.
    It just happens. So far it does not look at bad. Will check it out on better roads. If it has any issues will change them out for sure.
  5. W923
    W923 Road Train Member
    1,343
    4,095
    Feb 28, 2022
    If the flat spots aren’t too bad take the rims loose and turn them 180 degrees.
    Will still be balanced that way or at least closer. Has worked for me before.
    mtoo, D.Tibbitt, Beaver9 and 6 others Thank this.
  6. Phantom307
    222
    210
    Jul 5, 2019
    Cheyenne
    I like that idea, wish I would’ve thought of it!
  7. Rideandrepair
    17,342
    56,259
    Aug 8, 2015
    My Trailer had the wires spliced from being dragged, courtesy of Penske Trailer where I bought it. Supposedly splicing ABS is a DOT violation. I wasn’t ever bothered for it. Eventually it needed re splicing. Got a new one from Fleetpride at a great price. Some prices quoted were outrageous.
    Siinman and TooTiredToTalk Thank this.
  8. 201
    201 Road Train Member
    12,334
    25,218
    Apr 16, 2014
    high plains colorado
    I know, we've all run over stuff while seemingly watching the road, like "where the xxck did that come from?" A tire is a bit much, however, and just having the parking brakes come on shouldn't necessarily ruin the tires, you must have dragged them quite a ways. If the "clopping" tires bothers you, and will probably shake like the dickens, get some tires, fix the lines, and get going. Just another busy day in the trucking world. Get used to it, it's only going to get worse from here,,,but that's another subject,,oops, O/O section,dang, sorry.
  9. SmallPackage
    5,470
    17,383
    Dec 20, 2019
    Marion Texas
    Most manufacturers leave a couple extra feet of abs wire bundled together in the run for just this reason. Makes repair splices easier. Usually cable tied together somewhere out of the way. For years both Wabash and Freightliner did this.
    Siinman Thanks this.
  10. scott180
    scott180 Road Train Member
    1,217
    4,221
    Dec 10, 2012
    Tooele, UT
  11. Siinman
    5,289
    13,391
    Mar 5, 2017
    Kansas City, MO.
    I am gonna take it to Utility here in a few minutes. See if they can knock it out or at least have the parts so I can do it. It will be fine driving but I don’t have a load set up for today and so gonna just try and knock it out real fast. Rather have my stuff fixed with OEM parts and fill better about how it works.
