Rand Mcnally 530 heat and battery concerns.
Discussion in 'Trucking Electronics, Gadgets and Software Forum' started by Njp, May 2, 2015.
  1. Njp
    Njp Bobtail Member
    12
    Oct 27, 2013
    Mississauga, ON
    Hello,
    I just started driving OTR 1 week ago and purchased a RM530 based on the advice of trainer who has used many GPS' and settled on the RMM720.
    I've noticed a few problems related to battery and I was not able to find any info. on RM battery problems.
    1. The battery doesn't last very long, mine gives out after 30 mins of daytime usage. Is this normal and and if so are there overcharging problems with always keeping the unit plugged in.
    2. The heat, it got so hot that it left an imprint on my plastic binder, had to hold it up to a/c all the way home. I can't even imagine how hot it would get if left in sunlight.
    3. It never held a full charge, even when plugged in it would rarely get to 100% (green light) and if it did it would go down and up all the time. I'm just wondering if this is on purpose to avoid overcharging.
    I am using a 3.2amp and 1amp car charger with the factory cable, noticed heat on both chargers.
    The GPS itself is quite wonderful with many useful features and I was just wondering whether I have a defective unit or all units experience similar problems.
    Secondly does the Garmin counterpart to the 530 have similar issues?
  3. pumpkinhead
    pumpkinhead Light Load Member
    92
    56
    Mar 18, 2015
    I have the 720 and always keep it plugged in. I don't think these were made to run off of the battery for very long.
  4. SGTSmokdU
    SGTSmokdU Light Load Member
    179
    94
    Jun 5, 2012
    Alabama
    I run a 530...it stays plugged into its own outlet 24/7. Where it plugs into the back of the receiver, the connection could be a bit better. Im thunkijg that charger end of the cable may need a lil modifying.
  5. floored63
    floored63 Bobtail Member
    6
    Apr 30, 2015
    i have the 520LM and battery life is about the same 30-40 min. dont think mine gets that hot though.
  6. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    I would replace the charging chord. The outlet may problems too .. Can you try a different outlet ? You should be able to leave it plugged in 24/7
  7. Ridgeline
    22,362
    115,958
    NO it doesn't but I would get the latest large Garmin, the small one is just ... small to me.
  8. Njp
    Njp Bobtail Member
    12
    Oct 27, 2013
    Mississauga, ON
    Appreciate the replies. I'll try to change chord and the truck adapter. If all else fails I still have 15 days to return it so I'll try to get a new one or try out the Garmin.
  9. Ridgeline
    22,362
    115,958
    Why would you have to get a new charging cord?
    I mean if it is producing heat, then there is an internal problem with the charging system, not with the cord.
  10. dca
    6,834
    11,427
    May 31, 2011
    Earth
    I have had charging chords go bad or produce heat sometimes due to the outlet in use.
    Process of elimnation
  11. Ridgeline
    22,362
    115,958
    Being warm and as the OP put it "The heat, it got so hot that it left an imprint on my plastic binder, had to hold it up to a/c all the way home. [...]" seems to speak of a problem with the unit, not with the power source.
