I live in Connecticut, and the only roads that are highlighted in orange in the Rand McNally Atlas are the interstates. I noticed that some states such as Maine and New York have many roads highlighted in orange. The key, in the front of the map book, says that orange highlights mean: "designated route for vehicles with STAA authorized dimensions". Does that mean that these routes do not have overpasses under 13' 6" or restrictions?
Rand McNally Atlas
Discussion in 'Questions From New Drivers' started by LovemyGPS, Oct 28, 2010.
in the front of the atlas it should also list all low clearance locations by state and all restricted routes. The STAA authorized routes thing I always have to ask what that means cause I always forget but then again I run a reefer or dry box on the road not oversize stuff
Surface Transportation Act.......yes, you are ok on them !!
Look at the chart called State Access Policies. That states what each state allows you off the designated (orange) network. It doesn't guarantee no low underpasses, tho.... Just that you'll be legal within that many miles off the network. You should also double check the restricted routes/low underpass locations in the state breakdown section. The exception is if you are going to a shipper or receiver. In that case, you are allowed to take the most direct route.
