Random questions, replace all wheel seals or just the one that blew?
Discussion in 'Ask An Owner Operator' started by zaroba, Nov 21, 2021.
  1. zaroba
    zaroba Heavy Load Member
    840
    1,269
    Aug 28, 2012
    South East PA
    My trailer lost a wheel seal. Was strongly thinking of just replacing all 4 since if one went bad the other 3 wheel positions might not be too good either. Thoughts?
    I mean,
    That's what happened with my batteries, replaced one than a month later 2 others died so replaced the other 3.
    And my cab's airbags. Replaced 1, a week later another failed so just replaced the remaining 3.
    Dino soar, D.Tibbitt and Rideandrepair Thank this.
  3. kemosabi49
    10,670
    45,786
    Jan 13, 2013
    SW Arkansas
    With batteries you are usually better off replacing all of them as a set. Wheel seals I never did though. .
  4. Rideandrepair
    17,344
    56,268
    Aug 8, 2015
    I’d wait till it’s brake shoe time. I have 2 wheel seals on my drive axles with over 2 million miles. Check the bearings good for loose cages, Might want to check end play on the others. Too much is a common cause of seal failure. Otherwise just crawl under on occasion if you’re worried about the others. With a flashlight, you can look for any seepage, catching one before it blows.
  5. AModelCat
    159,369
    Batteries always, ALWAYS get replaced as a group.
    Wheel seals replace as needed.
  6. Dave_in_AZ
    389,003
    You're supposed to replace the batteries?
  7. Rideandrepair
    17,344
    56,268
    Aug 8, 2015
    Lol
    shooter19802003 Thanks this.
  8. Brandonpdx
    Brandonpdx Road Train Member
    4,257
    4,089
    Dec 27, 2007
    Elkhart, IN
    I wouldn’t do wheel seals proactively. Those others could go a long time. They will develop a slow seepage usually and give plenty of notice to somebody even paying halfway attention. Personally I don’t like any trailer or truck steer hub where I can’t easily see the oil level every AM on a quick walk around.
  9. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Is it totally blown? Like dripping out and making a mess? If not, I would leave it be and keep an eye on it. Sometimes they never start leaking out even when they're wet and they'll dry back out. Even if it is leaking I would just do the ones that are leaking instead of all of them. The only time I would do all four would be if I was already doing brakes anyway. It's not much more to do the seal from that point.
    Dino soar, shooter19802003 and zaroba Thank this.
  10. GYPSY65
    GYPSY65 Road Train Member
    1,957
    5,263
    Nov 16, 2012
    SW FLA
    Just replacing a a non leaking seal as a PM item may only cause a problem
    You can always get a bad part or install and then be back to square one
    D.Tibbitt, shooter19802003 and zaroba Thank this.
  11. zaroba
    840
    1,269
    Aug 28, 2012
    South East PA
    Yea, it's really blown, oil spraying on the wheel. The others are just doing the seeping thing, outside of the hubs just looks damp but there's no dripping (this one was like that too until I saw the oil all over the wheel on my walk around). They've been like that for months but they've held their oil inside.
    Thanks guys, I'll just do that one.
